PHP Date format in EUR (Italian)
Thread begun 11/11/2009 12:44 am by franconoviello319484 | Last modified 11/11/2009 12:49 pm by franconoviello319484 | 5046 views | 2 replies |
Hi
I'm a newby and getting a lot confused in formatting the date in dd/mm/yyyy,
I' ve checked the forum and on internet but I could'nt format the date in the recordset as:
DATE_FORMAT(date_in, %d %m,%Y)AS date_in
with the recordset qwery created by DataAsist it doesn't work so I'm tryng to format it by PHP on the page with no luck...
What can I do? here is the row to be chanched on the php page:
<tr>
<th class="WADADataTableHeader">data_in:</th>
<td class="WADADataTableCell"><?php echo($row_WADAapparato['data_in']); ?>
</td>
While this is the DataAssist Recordset:
SELECT id_apparato, tipologia_id, marca_id, modello_id, serial_num, ubicazione_id, data_in, note
FROM apparato
WHERE id_apparato = Paramid_apparato OR ( -1= Paramid_apparato2 AND id_apparato= ParamSessionid_apparato)
Can someone please help me?
Franco
Dani Chankhour
If you are using Times stamp as the data type in your table, i would recommend that you do the formatting on the page. and the function that you want to use is the date function and here is the link that explains how to use it:
function.date.php
Let me know if you have any other questions.
Hi Dani
I've changed the data type from "Date" to Time stamp and followed your suggestions and everything works fine now...
here is the row if someone needs it:
<td><?php echo($row_Recordset1['datin']); ?></td>
<td><?php echo date ('d/m/Y', strtotime($row_Recordset1['datin'])); ?></td>
Thank a lot for your help
Franco
Platform: MAC
Mac OS X 10.6 (Snow leopard)
Bootcamp (Windows 7)
