Css menu writer 2
Thread begun 11/09/2009 7:45 pm by julie777375638 | Last modified 11/10/2009 10:31 am by Eric Mittman | 1344 views | 1 replies |
julie777375638
Css menu writer 2
I have just recently installed css sculptor 3 upgrade. I am now trying to build a webpage using sculptor and once it is has been generated I go to use css menuwriter. When the menu is about to be execued I get the message
While executing onresize in WA_SITETOOLS_PROGRESS.htm the following javascript errors occured
infile WA_sitetools_progress refresh UI is not defined.
I am about to start a major project, so really need this to work. Does anybody know what this message means? I am using windows xp and dreamweaver cs4
You might be able to clear this up by deleting your cache file, here is a document with some instructions on this:
Please give this a try and let us know how this works for you.
