WA iRite removes images on update
Please see attachment for issue. (I can insert images and see images using WA iRite; however when I go to update using WA iRite the images don't show up; however are in the database.)
Thank you,
Julie
Thank you,
Julie
I moved this post to a new thread so that it doesn't confuse the other thread. I used the links in the document you posted but I was not able to get a good idea of the issue. Please describe what is occurring as best as you can and include some screen shots if you can. I will need to have a better understanding of the current issue to help out more.
I noticed when I followed my instructions it does not bring you the database content as you are not logged in, so please login at ourwebsite.com/Accounts/LogIn.php.
I would love send you screen shots and more information; however when I create the document and zip them they still are too big to upload to this forum. Can I send them somewhere else?
Once you log-in and go to the update page - the issue is with the WA iRite - right in the text box / field of the WA iRite. (I have a table with two columns and text on the right and an image on the left. However it does not show up. HOWEVER it does on the details page that I uploaded earlier.
Thank you,
Julie
Hi Julie,
I couldn't figure out which page you were referring to but if you could post the code of the page giving you trouble that would be great.
Best regards,
Brian
