menu open when inserted
Thread begun 11/09/2009 11:36 am by moretimbits342574 | Last modified 11/11/2009 7:18 am by neilo | 5578 views | 11 replies |
moretimbits342574
Just bought the program today and maybe I am missing something obvious. When I insert the menu it is open. I can't figure out why it is not collapsed. I have inserted it between the navigation tags.
can you post a link so we can examine the code.
moretimbits342574
open menu
have a look - index_test.html
Both my husband and I have Web Assist products. I have a MAC and he has a PC. Is it possible that somehow I downloaded a PC version of the program? That was one thought we had. Thanks for your help.
neilo
Hiya,
A couple of things - The 'CSSMenuWriter' and 'Scripts' folders don't appear to have uploaded to your web server. You need to upload both those folders.
Also, you will need to correct a couple of the paths to these folders in your 'index_test.html' page.
The paths in this bit of code inside the Head tags of your page:
<script src="Scripts/swfobject_modified.js" type="text/javascript"></script>
<script type="text/javascript" src="../CSSMenuWriter/cssmw7/menu.js"></script>
<style type="text/css" media="all">
@import url("../CSSMenuWriter/cssmw7/menu.css");
</style>
<!--[if lte IE 6]>
@import url("../CSSMenuWriter/cssmw7/menu_ie.css");
</style>
<![endif]-->
need to be changed to these:
<script type="text/javascript" src="CSSMenuWriter/cssmw7/menu.js"></script>
@import url("CSSMenuWriter/cssmw7/menu.css");
</style>
<!--[if lte IE 6]>
@import url("CSSMenuWriter/cssmw7/menu_ie.css");
</style>
<![endif]-->
moretimbits342574
open menu
I have changed the code as you suggested. Where do I find the folders 'CSSmenuWriter' and 'Scripts'? I assume I need to have these in my root folder - is that correct?
My other MAJOR problem is that I now cannot open my CSS Sculptor. I have used it for a long time with no problems but since I downloaded the menu writer it won't open. I get a screen that says -
While executing onload in wacs_wizard.htm the following javascript error occurred.
In file "wacs_wizard":
initialize UI is not defined.
At this point my MAC freezes. I cannot do a force quit and I have to manually shut it down.
Can you help me with this?
neil393381
Hiya moretimbits,
When you run CSSMenuWriter in Dreamweaver, it should place the CSSmenuWriter' and 'Scripts' folders in the root of your Dreamweaver site. Is it not doing this? If it isn't, maybe there's a problem with the way your site is defined in Dreamweaver's site definition. Might be worth checking 'Manage Sites' > Your Site and checking the structure of the local site for a clue as to where these folders are being placed.
Regarding the error message, - this seems to be a common occurence, and is a DreamWeaver fault, rather than a WebAssist Extension fault. The way that people seem to be solving this is by deleting the DreamWeaver 'MacFileCache' file
Instructions for doing that are Here
neilo
Oooh - I just bought some more extensions, and got logged in as a new user. Am both neilo and neil393381.
Contact the sales department at sales [at] webassist.com and they will be able to merge your two accounts.
neilo
Cheers Jason.
(I have enough trouble being one person never mind two)
moretimbits342574
No css menuwriter file
The 'Scripts' file is there in the root folder- but the menuwriter folder is not.
