Never a valid answer
Thread begun 11/08/2009 4:32 pm by jc1cell390254 | Last modified 11/12/2009 12:08 pm by Jason Byrnes | 8900 views | 22 replies |
jc1cell390254
I have placed the security features in my form that include the captcha and security question. Even if I put the correct answer it doesn't validate. I did not apply anything with security assist thinking this is a stand alone product which should validate automatically if the answer is correct.
Guidance on the matter would be great. I didn't see anything in UE or FB that would help me with it.
jc
Can you send a copy of your file so I can examine the code.
jc1cell390254
Here it is
I went ahead and recreated the form and applied universal email to it. Everything seems to work well until I send it. The only thing that errors is the security question even if it's the correct answer.
The file is attached.
Once the first error occurs I have to restart the browser in order to eliminate the message. I can go to any other page and return and the message is still there.
Thank your for looking into this.
jc
try changing line 15:
$WAFV_Errors .= WAValidateLE((isset($_POST["fieldset_group_nbsp"])?$_POST["fieldset_group_nbsp"]:"") . "",((isset($_SESSION["random_answer"]))?strtolower($_SESSION["random_answer"]):"") . "",true,5);
$WAFV_Errors .= WAValidateLE((isset($_POST["fieldset_group_nbsp"])?strtolower($_POST["fieldset_group_nbsp"]):"") . "",((isset($_SESSION["random_answer"]))?strtolower($_SESSION["random_answer"]):"") . "",true,5);
jc1cell390254
I'm afraid that didn't work. You can verify functionality at zona dot zonapromo dot net.
I changed the code and uploaded the new file and nothing. I had seen that in another post and tried it with no success. My issue is with numbers also not necessarily with upper lower issues. But then again, I know no php so your suggestion was well received.
jc
Just to double check that it is the Security Question failing, find the following code:
if ($WAFV_Errors != "")  {
    PostResult($WAFV_Redirect,$WAFV_Errors,"contactZonaPromo");
and change it to:
    die($WAFV_Errors);
this will write a comma separated list of numbers to the screen representing the validations that failed, please post that list back so I can look into this further.
jc1cell390254
So here's the result of that.
A blank page using the same url for the contact page with the following type:
,5
You can check the functionality at contactZonaPromo.php
jc
OK, so it is the security question that is failing validation,
To get a little more information on the problem, can you change the die statement:
die($WAFV_Errors);
echo("<pre>");
var_dump($_SESSION);
echo("</pre><br />");
die($WAFV_Errors."|".$_SESSION["random_answer"]."|".$_POST["fieldset_group_nbsp"]);
and post back the results.
jc1cell390254
here's the result of that:
array(3) {
["random_answer"]=>
&string(4) "cold"
["captcha_fieldset_group_Security_code"]=>
&string(5) "sDRN9"
["WAVT_contactZonaPromo_Errors"]=>
&string(0) ""
,5|cold|5
one more thing to try, After the <body> tag, add:
<pre><?php var_dump($_SESSION); ?></pre>
also send a copy of your WA_ValidationToolkit/WAVT_CaptchaSecurityQuestion.php
