Errors while opening CSS Forms Builder
Thread begun 11/08/2009 11:11 am by jc1cell390254 | Last modified 11/09/2009 5:05 pm by jc1cell390254 | 4753 views | 5 replies |
jc1cell390254
So I started using FB today and was having work fairly well. A couple of things confused me at first (how to edit a form after it's built - my guess is manually viewing the code). So I went back and forth re-creating my form until I thought it was right. At a certain point I decided to save what I was doing as a preset in the type of form and in the design. The first worked like a charm. The second gave me an error (saving_custom.... image that's attached) at first I cancelled the save but after pressing save again it went through. So I closed it.
I didn't like how it turned out so I tried opening FB again and now I get the error in the second attached image. I removed the extension and reloaded and replaced the needed files provided by WA.Still having the same issue. Now I can't use FB.
Any solutions?
thank you
jc1cell390254
What the messages say.
I just realized that the info in the messages can't be read so here they are:
1. Design:
"While executing onBlur n WAFB_SaveTheme.htm, a JavaScript error occurred."
2. Opening FB:
"While executing onLoad in WAFB_AddForm.htm, the following JavaScript error(s) occurred:
In file "WAFB_AddForm":
initializeUI is not defined"
jc1cell390254
Found solution to one issue
Here 146/ after searching the forum threads and finding showthread.php?t=4905&highlight=onLoad+error
Now searching for the other
jc1cell390254
Partially Solved
While I still get the error message when saving the design preset it does actually save it. I have since been able to complete my form.
If a solution ever comes up for that problem it would be great to sticky it for future encounters.
This can be marked solved.
jc
I have created a support ticket so we can look into this issue with you.
supporthistory.php?
jc1cell390254
Thank you Jason. I have taken the time to answer the ticket.
jc
