Error Messages
Thread begun 11/07/2009 7:12 am by dataworks388155 | Last modified 1/14/2010 11:20 am by Jason Byrnes | 5394 views | 10 replies |
dataworks388155
Error Messages
I am getting the following messages when I attempt to upload an image file using Digital File Pro
Warning: unlink(/hermes/web01c/b1006/hy.dcrawford/images/83925f911255331d339534f7e5621e1b.png) [function.unlink]: No such file or directory in /hermes/web01c/b1006/hy.dcrawford/WA_DigitalFilePro/HelperPHP.php on line 212
Warning: unlink(/hermes/web01c/b1006/hy.dcrawford/images/222d587f36fe6166541139fb484795a1.png) [function.unlink]: No such file or directory in /hermes/web01c/b1006/hy.dcrawford/WA_DigitalFilePro/HelperPHP.php on line 212
Warning: Cannot modify header information - headers already sent by (output started at /hermes/web01c/b1006/hy.dcrawford/WA_DigitalFilePro/HelperPHP.php:212) in /hermes/web01c/b1006/hy.dcrawford/reportbookrequest.php on line 178
Please Help. The file is attached in zip format
One thing I can see wrong on this page is the name of one of the file fields has a space at the beginning. Change:
html:
<input name=" RulesRegs" type="file" id=" RulesRegs" size="35" />
html:
<input name="RulesRegs" type="file" id="RulesRegs" size="35" />
If that does not resolve the problem, we will need to determine which of the file uploads is causing the error.
Remove the file upload server behaviors from the page on at a time to narrow down which one is causing the error, once we know that, we will have a better place to begin looking into the cause.
dataworks388155
Still a problem
Thanks but that did not resolve the problem. Deleted the space, Still getting the following errors
Warning: unlink(/hermes/web01c/b1006/hy.dcrawford/images/d35c6bf93d7158167a7f30d40758319b.png) [function.unlink]: No such file or directory in /hermes/web01c/b1006/hy.dcrawford/WA_DigitalFilePro/HelperPHP.php on line 212
Warning: unlink(/hermes/web01c/b1006/hy.dcrawford/images/926a650bef249bb863600c8c7331cc60.png) [function.unlink]: No such file or directory in /hermes/web01c/b1006/hy.dcrawford/WA_DigitalFilePro/HelperPHP.php on line 212
Did you try the rest of my suggestions:
dataworks388155
Yes
Yes, I did. Sorry. I know that it is the Upload Logo that is causing the problem. There are no errors when I delete this error.
Excellent, that information helps.
The logo is the only one you are resizing. resizing an image can take quite a bit of memory from the server.
Inthe php.ini file, increase the memory_limit setting, try setting it to 256M:
memory_limit = 256M
dataworks388155
What?
Please advise where I can find this php.ini file you are speaking about?
dataworks388155
No, Same Problem
I found the php.ini file (on my web server control panel), and edited it to change memory_limit from 10M to 256M, but am still getting the same error messages.
OK, Dani will be contacting you to look into this further.
Carl
Hi, has anyone figured out a solution to this error? I cannot change my memory_limit from 32M on my host and by the sounds of it, it does not work anyway.
My code is;
Warning: unlink(/home/blacklak/public_html/a32/portfolio/../../images/websites/large/f7ac1338ba0d76c58ab7658155880e86.png) [function.unlink]: No such file or directory in /home/blacklak/public_html/WA_DigitalFilePro/HelperPHP.php on line 212
Warning: unlink(/home/blacklak/public_html/a32/portfolio/../../images/websites/standard/964340bb4790e0cf41fff18e388309d8.png) [function.unlink]: No such file or directory in /home/blacklak/public_html/WA_DigitalFilePro/HelperPHP.php on line 212
Warning: unlink(/home/blacklak/public_html/a32/portfolio/../../images/websites/thumb/32af76e3e3a2ef1a7d75554a23431126.png) [function.unlink]: No such file or directory in /home/blacklak/public_html/WA_DigitalFilePro/HelperPHP.php on line 212
Warning: Cannot modify header information - headers already sent by (output started at /home/blacklak/public_html/WA_DigitalFilePro/HelperPHP.php:212) in /home/blacklak/public_html/a32/portfolio/insertimage.php on line 124
Line 212 in HelperPHP.php is the unlink($tmpFileNamePath); (as you know)
Line 124 in insertimage.php is header("Location: ".$WA_redirectURL); (which is the last part of the DataAssist Insert function.
Oh and it only happens when uploading .png files, if i upload .jpg files they work perfectly (except they are poor quality compared to the .png which is why I want to use the .png format)
Carl
