Positioning Forms
Thread begun 4/22/2009 7:14 pm by bobrossi315677 | Last modified 10/26/2009 10:02 am by Ray Borduin | 3543 views | 3 replies |
bobrossi315677
Positioning Forms
I realize that Dreamweaver templates can be used to style a contact form.
However, how can you place a form within, say an AP Div? Say you want a compact form to be placed in a left column panel, for example.
A good description of these options from WebAssist would be well appreciated.
There is no reason why you couldn't cut and paste a form into another container and change the size and format of the form elements to fit. I'm not sure what description you would expect for this. The best way to achive something is to give it a try and then when you run into a problem, then ask here what the solution is for that particular problem.
eladgraphics386618
contact form css problem
I have attached the form to my template and it is too big to fit where I want it. I can not get the fieldset so that I can change and set my own width in the css. All I can edit is the "form" or "label" but the size will not decrease, Where can I find the fieldset to change that.
For instance I want the whole contact form to fit in a 200px width (editable region)
I have set my security to 0 and still too dark to read, setting it up to 1 give me the same result.
Do you have a sample URL I can look at? There may be a couple of widths you have to adjust and the best way to give advise is to look at the current page.
