Default value for date for add to cart behavior
Thread begun 11/06/2009 10:57 am by sturgisk383938 | Last modified 11/11/2009 11:54 am by Jimmy Wu | 2676 views | 3 replies |
sturgisk383938
What would be a good default value to use for the date column? I have used mm/dd/yyyy and 00/00/0000. I want to bind the right default values for date to the cart. Can someone help me?
Jimmy Wu
I'm not sure exactly what you're asking. Could you explain what you're doing more clearly? What step of the wizard and which interface you're on would be helpful.
sturgisk383938
Date column
When you are adding the add to cart button to your product page. One of the things you have to do is set default values. My question is when setting the values for date the column. What would be the right value? I want the cart to reflect the current day of the purchase this is what I meant.
Jimmy Wu
This is for a column you've manually added?
You can use some SQL functions to insert the correct date into the database:
sql_dates.asp
