Number of markers that display is not consistant
Thread begun 11/06/2009 10:15 am by office125319 | Last modified 11/09/2009 8:16 am by office125319 | 5391 views | 8 replies |
office125319
I have a web page, atac-membership-search-results.asp, that displays member office locations in a Google Pro Map. Try searching for Yorkshire, West members and you will see the recordset that displays the list of members displays 12 members in the list. The map uses a seperate recordset generated from the same data source via a stored procedure. The map markers sometime appear as 12 and sometimes 11 and sometimes 10 in number. I have tried inserting the code "rsMap_cmd.ActiveConnection.cursorLocation = 3 " in to the map recordet code as suggested in another thread on the forum ( see below ) but this doesn't resolve the problem!
Dim rsMap
Dim rsMap_cmd
Dim rsMap_numRows
Set rsMap_cmd = Server.CreateObject ("ADODB.Command")
rsMap_cmd.ActiveConnection = MM_ConnARCAD_STRING
rsMap_cmd.CommandText = "EXEC uspFindATaCMembersMap ?"
rsMap_cmd.Prepared = true
rsMap_cmd.Parameters.Append rsMap_cmd.CreateParameter("param1", 200, 1, 50, rsMap__MMColParam) ' adVarChar
Set rsMap = rsMap_cmd.Execute
rsMap_numRows = 0
I understand there is an XML cache file used by Pro Maps to help speed up the map display and that this can cause problems. Can this cache file by turned off? Also where do you find the cache file to delete it?
If someone could kindly point me in the right direction to get this reseolved I would be most grateful.
David
Jimmy Wu
I've loaded the map several times and I always get the same result. Is there any consistency to which results are left out for you?
The Cache file will be in the _promaps_cache directory. There isn't an option to turn off caching however.
office125319
Markers
Jimmy, thanks for your reply. Have you used the search menu to view the map for "Yorkshire, West" members? If you have then have you seen 12 markers each time you refresh this page. I will get anything ranging from 9 - 12. I don't get 12 each time which is the issue I am trying to resolve. Could you kindly take another look and let me know if you can see the issue I have described and possible fixes. Thanks!
Most likely the problem is that the cache file isn't working properly. The cache file fixed the problem where maps with more than 10 data points could stop working because of too many geocache calls. I think you actually need to figure out how to get the cache file working and not how to disable it.
Were you not able to find it? My bet is that it can't create it because of permissions. I'd create the cache file in the proper location manually so that it can start working. I'll bet that will fix the issue.
office125319
Markers
Thanks Ray for your advice. However, when you say "create the cache file in the proper location manually so that it can start working" could you kindly let me have some detailed instructions on how to do this. Cheers!
office125319
Markers
Hi Guys,
I really need a full and proper answer from you to this issue of markers not displaying, because at the moment it is not working reliably. If you know your MAP EXTENSION doesn't work reliably then appreciate knowing this as I can spend my time trying to source a solution with Google. If, as I hope, it does work reliably then I really need a detailed TO DO LIST from you on what needs checking and what needs changing to ensure that the right number of markers display consistently.
Just to recap. If you go to www.atac.org.uk and use the Find A Member search form for say "Yorkshire, West" you will see 12 members listed in the left column and on the Google Map you will see anything from 9 - 12 markers for these same members.
I have just ran a test by searching for "Glamorgan" - 5 out 6 markers show ; "Essex" - 10 out of 13 arkers show ; "Yorkshire, West" - 10 out of 12 markers show ; Yorkshire, South" - 6 out 6 markers show. If I run this test again I would get slightly different results. Clearly there is something going on which is a not working 100% reliably.
The search web page that displays the results uses the same database table and strored procedure to retrieve the data for both the list and the map. I have executed the map stored procedure on the server with a variety of input parameters and it works perfectly, i.e. retrurns the correct number of records. The problem then is not with the recordset or stored procedure. I have pasted below the ASP code that shows the 2 stored procedure in the search results page below.
The only other file used is your asp include file. I have pasted the code for this below as well.
I would be most grateful if you could provide me with a detailed set of instruction on resolving this problem. ATAC are a very important client of mine I need this working 100%.
I look forward to hearing from you soon and appreciate your help.
SOURCE CODE FOR SEARCH RESULTS WEB PAGE
Dim rsMap__MMColParam
rsMap__MMColParam = "Surrey"
If (Request.Form("County") <> "") Then
rsMap__MMColParam = Request.Form("County")
End If
Dim rsMap
Dim rsMap_cmd
Dim rsMap_numRows
rsMap_numRows = 0
Dim rsMembers__MMColParam
rsMembers__MMColParam = "Surrey"
rsMembers__MMColParam = Request.Form("County")
End If
Dim rsMembers
Dim rsMembers_cmd
Dim rsMembers_numRows
Set rsMembers_cmd = Server.CreateObject ("ADODB.Command")
rsMembers_cmd.ActiveConnection = MM_ConnARCAD_STRING
rsMembers_cmd.CommandText = "EXEC uspFindATaCMembers ?"
rsMembers_cmd.Prepared = true
rsMembers_cmd.Parameters.Append rsMembers_cmd.CreateParameter("param1", 200, 1, 50, rsMembers__MMColParam) ' adVarChar
Set rsMembers = rsMembers_cmd.Execute
rsMembers_numRows = 0
Dim RepeatMembers__numRows
Dim RepeatMembers__index
RepeatMembers__numRows = -1
RepeatMembers__index = 0
rsMembers_numRows = rsMembers_numRows + RepeatMembers__numRows
SOURCE CODE FOR ASP INCLUDE FILE
function wagmp_map_1() {
if(GBrowserIsCompatible()) {
if(!document.getElementById('wagmp_map_1')) return false;
var map = new GMap2(document.getElementById('wagmp_map_1'));
map.enableContinuousZoom();
map.enableDoubleClickZoom();
map.addControl(new GSmallZoomControl());
var geocoder = new GClientGeocoder();
var fromAddress = {
enabled: false,
street: '',
city: '',
state: '',
zip: '',
country: '',
full: ''
var icon_0 = new GIcon();
icon_0.image = 'http://google.webassist.com/google/markers/traditionalflat/pacifica.png';
icon_0.shadow = 'http://google.webassist.com/google/markers/traditionalflat/shadow.png';
icon_0.iconSize = new GSize(34,35);
icon_0.shadowSize = new GSize(34,35);
icon_0.iconAnchor = new GPoint(9,23);
icon_0.infoWindowAnchor = new GPoint(19,0);
icon_0.printImage = 'http://google.webassist.com/google/markers/traditionalflat/pacifica.gif';
icon_0.mozPrintImage = 'http://google.webassist.com/google/markers/traditionalflat/pacifica_mozprint.png';
icon_0.printShadow = 'http://google.webassist.com/google/markers/traditionalflat/shadow.gif';
icon_0.transparent = 'http://google.webassist.com/google/markers/traditionalflat/pacifica_transparent.png';
Dim rsMap_repeat_index
rsMap_repeat_index = 0
While (NOT rsMap.EOF)
var address_0_<%=CStr(rsMap_repeat_index)%> = {
street: '',
city: '',
state: '',
zip: '',
country: '',
infowindow: 'custom',
infowindowtext: '<span style="font: 12px Verdana, Arial, Helvetica, sans-serif; color: black;"><%=Replace(Cstr("<strong>" & cStr((rsMap.Fields.Item("CompanyName").Value)) & "</strong><br><br />" & cStr((rsMap.Fields.Item("OfficeAddress1").Value)) & "<br>" & cStr((rsMap.Fields.Item("PostCodeTown").Value)) & " " & cStr((rsMap.Fields.Item("PostCode").Value)) & ""), "'", "\'")%></span>',
full: '<%=Replace(Cstr("" & cStr((rsMap.Fields.Item("Lat").Value)) & ""), "'", "\'")%>,<%=Replace(Cstr("" & cStr((rsMap.Fields.Item("Long").Value)) & ""), "'", "\'")%>',
isdefault: true,
addressType: 'coordinates',
loop: 'rsMap',
latitude: '<%=Replace(Cstr("" & cStr((rsMap.Fields.Item("Lat").Value)) & ""), "'", "\'")%>',
longitude: '<%=Replace(Cstr("" & cStr((rsMap.Fields.Item("Long").Value)) & ""), "'", "\'")%>',
markerStyle: 'Google Traditional (flat)',
markerColor: 'Pacifica'
geocoder.getLatLng (
address_0_<%=CStr(rsMap_repeat_index)%>.full,
function(point) {
if(point) {
var marker = new GMarker(point, icon_0);
GEvent.addListener(marker, 'click', function() {
marker.openInfoWindowHtml(address_0_<%=CStr(rsMap_repeat_index)%>.infowindowtext);
if(!fromAddress.enabled || 'address_0_<%=CStr(rsMap_repeat_index)%>' != 'address_0_0') {
map.setCenter(point, 9);
map.addOverlay(marker);
else {
rsMap_repeat_index = rsMap_repeat_index + 1
rsMap.MoveNext()
Wend
It looks like you may be using an older version of Google maps without the cache file.
What version do you have installed? I don't see any reference to the cache file, which I believe will be the solution to this problem.
office125319
Markers
Thanks Ray,
You are right, I am using version 1.0.0. I will download the latest version and see what happens.
office125319
Markers
Just to let you know that the latest version 1.0.6 resolved all the problems!! Thanks for pointing me in the right direction.
