Contact Form Re-enter Email address
Thread begun 11/06/2009 7:13 am by rog4679 | Last modified 3/17/2016 12:04 pm by anonymous | 12561 views | 6 replies |
rog4679
I created a new PHP and inserted a 'contact' form using css form builder. The email address field and re-enter email address field are supposed to match.
Why does the form validate email address entries that don't match?
There are no recordsets in either bindings or server behaviors. I'm not trying to check form entries against my database.
My contact form-
Name
email
re-enter email
captcha
submit button
rog4679
wrong error message
In addition to the error for email addresses validation without match, I'm getting a wrong error message in the email address fields.
If I type in a value that is not the same as the email it gives me the error message that a value is required and if it has no value it says that the email addresses do not match.
I've reviewed my code and don't see the difference -
<div class="errorGroup">
<div class="fieldPair">
<div class="fieldGroup"> <span id="Contact_me_group_Re_enter_your_email_address_Spry">
<input id="Contact_me_group_Re_enter_your_email_address" name="Contact_me_group_Re_enter_your_email_address" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("visitorsnewLogin","Contact_me_group_Re_enter_your_email_address"):"")); ?>" class="formTextfield_Large" tabindex="4" onblur="hideServerError('Contact_me_group_Re_enter_your_email_address_ServerError');"/>
<span class="textfieldInvalidFormatMsg">Invalid format.</span><span class="textfieldRequiredMsg">The email address entered doesn't match</span> </span>
if (ValidatedField('visitorsnewLogin','visitorsnewLogin')) {
if ((strpos((",".ValidatedField("visitorsnewLogin","visitorsnewLogin").","), "," . "3" . ",") !== false || "3" == "")) {
if (!(false)) {
<span class="serverInvalidState" id="Contact_me_group_Re_enter_your_email_address_ServerError">The email address entered doesn't match</span>
<?php //WAFV_Conditional visitors_newLogin.php visitorsnewLogin(3:)
</div>
Jimmy Wu
Do you have a page where I can see this behavior happening?
How are you applying the validation that checks if the emails are the same?
rog4679
Bug in the code generated by Form Builder?
Hello -
I've attached the page. All the code was generated in form builder. I purposely generated a document entirely with the webassist extension.
Thanks.
Also, as a side note. No matter how I build a form, Universal email won't send the document due to excess spam in the mail function.!
FROM ENOM - we don't support the Mail() function due to excessive spam. Request an alternative mail function.
CSS Form Builder does not offer the ability to add Like Entry validation to text fields that you create in your form, you need to add this after the form is created.
This is because in addition to adding the server side validation, it is adding Client side Spry validatin that does not offer a like entry option.
To add Like Entry validation:
double click the Server Validation server behavior.
From the Validation type list, select Like Entry.
Click the Lightning bolt next to server variable and select the email address form element. Click the plus button, in the next screen, select the re enter email address form element.
As for the message from Enom, this instance of Universal Email uses the Mail mail object, use Pear Mail for SMTP instead as I stated in your other thread.
anonymous
This post has been deleted.
anonymous
