Error while adding "Look up item from recordset"
Thread began 11/05/2009 7:53 am by fdotmedia | Last modified 11/05/2009 12:38 pm by fdotmedia | 1181 views | 2 replies |
fdotmedia
I'm adding a set of dynamic data... After clicking the add to cart button in the eCart toolbar, I clicked on the Look up item radio button and get the following error...
At line 907 of file "Path/To/Configuration/commands/WA eCart AddToCart.js":
document.generalWP.document.column.options
[document.generalWP.document.column.selectedIndex] has no properties
I've deleted my dat file...
any ideas?
What version of eCart do you have installed?
Please make sure you have installed the latest version that is available from the download center.
if you have a previous version installed, make sure to remove it from the Extension Manger before installing the newer one.
fdotmedia
4.5.2
I actually just uninstalled then reinstalled eCart 4.5.2...
Same error... line 907...
I am on OSX 10.6.1
