Show Region (if certain user level) not working
Thread begun 11/05/2009 5:18 am by larsentim278054 | Last modified 11/05/2009 11:34 am by Jason Byrnes | 5057 views | 8 replies |
larsentim278054
I'm using a regular WebAssist menu on a restricted page. And on that page, in the navigation, I have a link that I only want Administrators to see (a certain user level). So in the menu.php file, I highlight the LI tag that I only want to show to administrators, then go to insert and in SA's options, I click on Show Region.. Then I select Administrator. I save and upload the menu.php file, but I now get an error when it tries to display the page. This is the error:
Warning: require_once(../../WA_SecurityAssist/Helper_PHP.php) [function.require-once]: failed to open stream: No such file or directory in /home/thelarse/public_html/marinacondosmadison/CSSMenuWriter/cssmw/menu.php on line 1
Fatal error: require_once() [function.require]: Failed opening required '../../WA_SecurityAssist/Helper_PHP.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/thelarse/public_html/marinacondosmadison/CSSMenuWriter/cssmw/menu.php on line 1
What do I need to do?
in the CSSMenuWriter/cssmw/menu.php file try changing the path to the WA_SecurityAssist/Helper_PHP.php page form:
../../../WA_SecurityAssist/Helper_PHP.php
larsentim278054
I tried that. Doesn't help. I also tried just using "/" and that didn't help either. Same error message (only difference is that is adds the ../ to the url in the error message.
can you post a URL.
larsentim278054
No, not really. You need to have login details.
larsentim278054
Do you want me to upload any certain pages?
It's fine if i cant get to the page really, I just need to be able to see the URL to the page in relation to the location of the SecurityAssist folder on your site.
the error is occurring in the CSSMenuWriter/cssmw/menu.php, if I could just have a link to that page, I can probably figure the error out.
larsentim278054
As I was replying, I realized what you were trying to figure out. It's only one folder back from where that php file is. So I made it just ONE ../ and it works now.
Thanks!
;) Nicely done.
