cash on collect
Thread begun 11/04/2009 10:37 pm by parigiro318823 | Last modified 11/12/2009 10:33 am by Jason Byrnes | 6694 views | 13 replies |
parigiro318823
cash on collect
Some customer here in Italy prefer to pay cash at delivery of goods they don't like use credita card or paypal
how can implement this extra feature ( in addition to paypal?)
roberto
On the checkout form, add a Cosh On Delivery Check box and set the checked value to 1:
<input type="checkbox" name="cashoncollect" id="cashoncollect" value="1"/>
On the confirm page, create a hidden form element with the same name, and set the value to be captured from the one on the checkout page:
<input type="hidden" name="cashoncollect" id="cashoncollect" value="<?php echo((isset($_POST["cashoncollect"]))?$_POST["cashoncollect"]:"") ?>"/>
Around the paypal local checkout code, add the following if statement:
<?php if(isset($_POST["cashoncollect"]) && $_POST["cashoncollect"] == "1") { ?>
<local checkout code>
} else {
eCart Object Name>->redirStr "checkout_success.php";
where <eCart Object Name> is the name of the eCart object.
parigiro318823
paymente on collect
it is possible to store order , cart details and customer data in thedatabase without going to paypal or other external site ? ?
i mean when customer press checkout he is asked to enter his personal data
after that shopping cart and personal data are shown with the option to confirm or delete po or change po
when he press confirm , order , carts detail, and customer details are saved in the proper table and mail of PO confirnation is sent to customer
it is possible to do that ?
thanks
If you want the option, then use the if statement around the local checkout code.
If not, delete the local checkout server behavior.
parigiro318823
cash on delivery
sorry but i don't understand i used checkout wizard exactly the same as per you getting started guide but i don't understand were i need to put the code you show to me above
roberto
parigiro318823
cash on collect
sorry can i have an answer ?
it is useless to get just generic answer not quoting a step by step procedures
for example another problem
when i try to enter payment by card i get this message we are sorry.....
i think that having bought many extension a little bit of support should be supplied
thks
On the confirm page, there will be a local checkout server behavior listed in the server behaviors list.
Select the server behavior, then go to code view, the local checkout server behavior code will be highlighted, place the If statement around the highlighted code.
parigiro318823
CAsh on collect
i got this message
"Warning: Cannot modify header information - headers already sent by (output started at C:\Inetpub\www\WACART1\confirm.php:142) in C:\Inetpub\www\WACART1\confirm.php on line 269
This error happens when there is some sort of output on the page before the header function is used to redirect to another page.
This part of the error:
is saying the output is at line 141 or 142.
It may be a blank space after a closing php tag:
or a blank line after a closing php tag before the next opening tag:
<?php...
See the following for more details:
148/
parigiro318823
cash on collect
no this is not clear at all
thats the code can do necessary modification ????
thks
if (($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)) {
$PP_DirectPayment_required = array();
$PP_DirectPayment_required[0] = array();
$PP_DirectPayment_required[1] = array();
$PP_DirectPayment_itemized = array();
$PP_DirectPayment_itemized[0] = array();
$PP_DirectPayment_itemized[1] = array();
$PP_DirectPayment_optional = array();
$PP_DirectPayment_optional[0] = array();
$PP_DirectPayment_optional[1] = array();
$cartIndex = 0;
$nextIndex = 0;
$nextIndex = count($PP_DirectPayment_required[0]);
$PP_DirectPayment_required[0][$nextIndex] = "Username";
$PP_DirectPayment_required[1][$nextIndex] = "########";
$PP_DirectPayment_required[0][$nextIndex] = "Password";
$PP_DirectPayment_required[0][$nextIndex] = "Signature";
$PP_DirectPayment_required[1][$nextIndex] = "##############################";
$PP_DirectPayment_required[0][$nextIndex] = "PaymentAction";
$PP_DirectPayment_required[1][$nextIndex] = "Sale";
$PP_DirectPayment_required[0][$nextIndex] = "Currency";
$PP_DirectPayment_required[1][$nextIndex] = "USD";
$PP_DirectPayment_required[0][$nextIndex] = "IPAddress";
$PP_DirectPayment_required[1][$nextIndex] = "".$_SERVER["REMOTE_ADDR"] ."";
$PP_DirectPayment_required[0][$nextIndex] = "CreditCardType";
$PP_DirectPayment_required[1][$nextIndex] = "".((isset($_POST["cc_type"]))?$_POST["cc_type"]:"") ."";
$PP_DirectPayment_required[0][$nextIndex] = "CreditCardNumber";
$PP_DirectPayment_required[1][$nextIndex] = "".((isset($_POST["cc_number"]))?$_POST["cc_number"]:"") ."";
$PP_DirectPayment_required[0][$nextIndex] = "ExpMonth";
$PP_DirectPayment_required[1][$nextIndex] = "".((isset($_POST["exp_month"]))?$_POST["exp_month"]:"") ."";
$PP_DirectPayment_required[0][$nextIndex] = "ExpYear";
$PP_DirectPayment_required[1][$nextIndex] = "".((isset($_POST["exp_year"]))?$_POST["exp_year"]:"") ."";
$PP_DirectPayment_required[0][$nextIndex] = "FirstName";
$PP_DirectPayment_required[1][$nextIndex] = "".((isset($_POST["firstname"]))?$_POST["firstname"]:"") ."";
$PP_DirectPayment_required[0][$nextIndex] = "LastName";
$PP_DirectPayment_required[1][$nextIndex] = "".((isset($_POST["lastname"]))?$_POST["lastname"]:"") ."";
$PP_DirectPayment_required[0][$nextIndex] = "Street1";
$PP_DirectPayment_required[1][$nextIndex] = "".((isset($_POST["street1"]))?$_POST["street1"]:"") ."";
$PP_DirectPayment_required[0][$nextIndex] = "CityName";
$PP_DirectPayment_required[1][$nextIndex] = "".((isset($_POST["city"]))?$_POST["city"]:"") ."";
$PP_DirectPayment_required[0][$nextIndex] = "StateOrProvince";
$PP_DirectPayment_required[1][$nextIndex] = "".((isset($_POST["state_province"]))?$_POST["state_province"]:"") ."";
$PP_DirectPayment_required[0][$nextIndex] = "PostalCode";
$PP_DirectPayment_required[1][$nextIndex] = "".((isset($_POST["postcode"]))?$_POST["postcode"]:"") ."";
$PP_DirectPayment_required[0][$nextIndex] = "Country";
$PP_DirectPayment_required[1][$nextIndex] = "".((isset($_POST["country"]))?$_POST["country"]:"") ."";
$PP_DirectPayment_required[0][$nextIndex] = "UseSandbox";
$PP_DirectPayment_required[1][$nextIndex] = "true";
$PP_DirectPayment_itemized[0][0] = "OrderTotal";
$PP_DirectPayment_itemized[1][0] = "".$eCart1->GrandTotal() ."";
$PP_DirectPayment_itemized[0][1] = "OrderDescription";
$PP_DirectPayment_itemized[1][1] = "";
while ( !$eCart1->EOF() ) {
$nextIndex = count($PP_DirectPayment_itemized[0]);
$PP_DirectPayment_itemized[0][$nextIndex] = "Amount" . strval($cartIndex+1) . "";
$PP_DirectPayment_itemized[1][$nextIndex] = "".$eCart1->DisplayInfo("Price") ."";
$PP_DirectPayment_itemized[0][$nextIndex] = "Name" . strval($cartIndex+1) . "";
$PP_DirectPayment_itemized[1][$nextIndex] = "".$eCart1->DisplayInfo("Name") ."";
$PP_DirectPayment_itemized[0][$nextIndex] = "Number" . strval($cartIndex+1) . "";
$PP_DirectPayment_itemized[1][$nextIndex] = "".$eCart1->DisplayInfo("ID") ."";
$PP_DirectPayment_itemized[0][$nextIndex] = "Quantity" . strval($cartIndex+1) . "";
$PP_DirectPayment_itemized[1][$nextIndex] = "".$eCart1->DisplayInfo("Quantity") ."";
$eCart1->MoveNext();
$cartIndex ++;
$eCart1->MoveFirst();
$nextIndex = count($PP_DirectPayment_optional[0]);
$PP_DirectPayment_optional[0][$nextIndex] = "MerchantSessionID";
$PP_DirectPayment_optional[1][$nextIndex] = "".session_id() ."";
$PP_DirectPayment_optional[0][$nextIndex] = "Payer";
$PP_DirectPayment_optional[1][$nextIndex] = "".((isset($_POST["email"]))?$_POST["email"]:"") ."";
$PP_DirectPayment_optional[0][$nextIndex] = "Street2";
$PP_DirectPayment_optional[1][$nextIndex] = "".((isset($_POST["street2"]))?$_POST["street2"]:"") ."";
$PP_DirectPayment_optional[0][$nextIndex] = "Phone";
$PP_DirectPayment_optional[1][$nextIndex] = "".((isset($_POST["phone"]))?$_POST["phone"]:"") ."";
$PP_DirectPayment_optional[0][$nextIndex] = "CVV2";
$PP_DirectPayment_optional[1][$nextIndex] = "".((isset($_POST["cvv"]))?$_POST["cvv"]:"") ."";
$PP_DirectPayment_optional[0][$nextIndex] = "ItemTotal";
$PP_DirectPayment_optional[1][$nextIndex] = "".$eCart1->TotalColumn("TotalPrice") ."";
$PP_DirectPayment_optional[0][$nextIndex] = "ShippingTotal";
$PP_DirectPayment_optional[1][$nextIndex] = "".$eCart1->GetShipping() ."";
$PP_DirectPayment_optional[0][$nextIndex] = "HandlingTotal";
$PP_DirectPayment_optional[1][$nextIndex] = "".$eCart1->GetCharges() - $eCart1->GetDiscounts() ."";
$PP_DirectPayment_optional[0][$nextIndex] = "TaxTotal";
$PP_DirectPayment_optional[1][$nextIndex] = "".$eCart1->GetTax() ."";
$WAGatewayResponse = PP_DirectPayment_Post($PP_DirectPayment_required,$PP_DirectPayment_itemized,$PP_DirectPayment_optional);
if ($WAGatewayResponse) {
$eCart1->redirStr = "checkout_success.php";
else if ("checkout_failure.php" != "") {
header("Location: ". "checkout_failure.php");
exit();
} else {
