Perhaps a Small Bug
Thread began 11/04/2009 7:35 pm by anonymous | Last modified 11/12/2009 4:00 pm by Dani Chankhour | 2650 views | 7 replies |
anonymous
Perhaps a Small Bug
I have noticed now on repeated occasions that when applying the initial value for the HTML Editor on an update page, for instance, that the initial value does not "stick" and get placed in the code. It does, though, stick if you reopen the editor using the edit button after it placed on the page and then hit the lightning bolt again and add the recordset or other variable to set the initial value.
I made sure the behavior was the same on several attempts before posting this... but now that I have experienced the same issue on several different sites, I have come to the conclusion that it is probably a bug of sorts. I am using Mac OSX 10.6.1 and Dreamweaver CS4.
Cheers,
Brian
Dani Chankhour
Do you encounter the same issue if you tab out the initial value input field.
Sometime Dreamweaver needs to change focus in order to save value.
Let me know if that helped or not.
anonymous
Hi Dani,
Yeah, I made sure to use both tab and return before reporting the problem. Because I remember that issue upon the launch of the DFP2, so I did try to change the focus and still had the same problem.
Brian
Dani Chankhour
I was not able to reproduce the issue you are experiencing. Could you please outline the steps you are talking, and if it is a bug i will report it.
Thanks.
anonymous
Hi Dani,
Sorry for the delay in getting you this information.
Here's what I am doing when I get the bug:
First, I run the DataAssist wizard to create my DataAssist results, search, update, and insert pages.
For my content area, in DataAssist, I am first defining it as a text area.
Then on the update page, I apply the HTML Editor to the text area. Inside the HTML Editor dialog box for "Initial Value," I click the lightning bolt and then select the corresponding value from the recordset to bind to the HTML Editor instance and then hit OK to save the editor.
A check of the code shows the initial value is not maintained or added to the code. But if I enter the dialog again and add the initial value (the same way as described before) a second time, it then adds the correct code.
Best regards,
Brian
Dani Chankhour
Thanks.
I have logged a bug in our bug base and we should get a fix in our next dot release.
Again thanks.
Remco209061
Irite was better
Hello I have the same problem.
The older version was better never a'n update problem.
I work with Vista and Dreamweaver CS4.
grts remco
Dani Chankhour
The update should work the second time you reenter the html editor quick insert.
