nearly there
Thread begun 11/04/2009 11:07 am by i.edwards384429 | Last modified 11/05/2009 1:44 pm by Jason Byrnes | 6323 views | 7 replies |
i.edwards384429
nearly there
Ok the title is not desacriptive to you but it is to me!!!!!
Last problem ( Ok it wont be)
used the dataassist search wizard and the tutorial line by line to create the search at
search.php
So I wasted an hour working out it failed to work because I did not havbe any data in the table ( my turn for the brain cell tomorrow)
So I added three records and as I had only added one search criteria that of sex thought I could search on either male or female.
When I select the dropdown box I see the gender enrty for all three records listed.
So it seems to me that I am displaying the records from the table rather than doing a search.
I am of course only using the users table from the solution do I need two tables to acheive the search function?
thanks
Ian
On the search, you need to modify the recordset you are using to populate the list:
SELECT DISTINCT genderColumn FROM tblName
using DISTINCT will filer out duplicates.
i.edwards384429
Update
Hi Jason
there I was saying I was nearly there ;-)
In my search.php
(search.php)
I changed the record set - first selecting the advanced button - to
SELECT DISTINCT UserAge,UserSex,UserTypes,UserArea,UserEthnicity
FROM users
where UserAge,UserSex,UserTypes,UserArea and UserEthnicity are the field names.
However when I run the page on my test server it still when I use the box select arrow choices of
male
female
male
Is this recordset codong correct?
thanks
Ian
The distinct key word returns a distinct result for all of the columns in the select statement.
Where you only need the UserSex column to be returned, it should be the only column in your select statement
SELECT DISTINCT UserSex
FROM users
IF you *did* need all of the other columns returned, dont use distinct, use GROUP BY:
SELECT UserAge,UserSex,UserTypes,UserArea,UserEthnicity
FROM users GROUP BY UserSex
For more information on the DISTINCT key word:
sql_distinct.asp
For more info on GROUP BY:
sql_groupby.asp
i.edwards384429
update
Hi Jason
don't seem to be getting very far as I still have the same issuedespite implementing your last code suggestion
I cant get the search at search.php to behave as I want it to.
I need to search the database and allow the user by means of the drop down box to create their own filter ie show them Males who are asian and who are between 30-40 years old.
The search does work but all of the select boxes seem to want to show the entries for each record.
Are searches supposed to work in this way in mysql?
thanks
Ian
can you send a copy of the search page?
i.edwards384429
update
Hi Jason
I've zipped up the search,results and an sql dump and uploaded them.
thanks again
Ian
Your search page defines the rsItems recordset three times in a row:
$query_rsitems = "SELECT UserAge,UserSex,UserTypes,UserArea,UserEthnicity FROM users GROUP BY UserSex";
$rsitems = mysql_query($query_rsitems, $localhost) or die(mysql_error());
$row_rsitems = mysql_fetch_assoc($rsitems);
$totalRows_rsitems = mysql_num_rows($rsitems);
$query_rsitems = "SELECT DISTINCT UserAge,UserSex,UserTypes,UserArea,UserEthnicity FROM users";
$query_rsitems = "SELECT DISTINCT UserAge, UserTypes, UserArea,UserSex FROM users";
PHP cpde is run from line 1 to the end, one line at a time, by the time you get to the code that creates the select list using the rsitems recordset, the last on is the one that is being used:
Hers what you need to do:
Create a recordset fro each select list, one for the gender, one for the ethincity, one for the age etc....
rsGender:
SELECT DISTINCT UserSex FROM users
rsAge:
SELECT DISTINCT UserAge FROM users
rsType:
SELECT DISTINCT UserTypes FROM users
rsArea:
SELECT DISTINCT UserArea FROM users
rsEthnicity:
SELECT DISTINCT UserEthnicity FROM users
Each select list should use the recordset created for that list. The Gender list uses the rsGender recordset. The Age list uses the rsAge recordset etc....
