Adding Static Links Breaks Dynamic Links
Thread begun 11/04/2009 3:54 am by mrobben375515 | Last modified 11/06/2009 10:42 am by Jason Byrnes | 4257 views | 5 replies |
mrobben375515
We are using PowerStore and SuperSuite. We implemented the PowerStore as is out of the box. All the menu links work as expected. The site is www. funphotobooks.com. When we use the CSS Menu Writer tools and add a static page to the About Us page, the dynamic menus for the products break. Here is what we are doing:
1. Open the index.php page
2. click on the menu to bring up the CSS Menu Writer buttons
3. clink on Edit Contents
4. click on the About Us item
5. click the Add Static link button
6. map that new link to the owerns.php page
7. save the preset
We they sync the site and upload the 3 new pages that we changed,
1. CSSMenuWriter\cssmw_home\menu.css
2. CSSMenuWriter\cssmw_home\menu.js
3. CSSMenuWriter\cssmw_home\menu.php
We are also told that 3 other files are out of sync so we put these in also:
CSSMenuWriter\cssmw_home\menu_ie.css
CSSMenuWriter\cssmw_home\menustyle.xml
CSSMenuWriter\cssmw_home\tree.xml
can you send a copy of the CSSMenuWriter\cssmw_home\menu.php from before making the change and another copy after making the change so I can inspect the code to see what is going wrong.
mrobben375515
menu.php file
Here is the file you requested.
try changing line 23:
require_once($WA_dotDotSlash . "Connections/localhost.php");
//require_once($WA_dotDotSlash . "Connections/localhost.php");
mrobben375515
Same problem
I am attaching the menu*.* files. That recommendation did not work. The dynamic link broke again.
There is no attachment to your reply.
I really only need to see the menu.php page, can you also send a link to the menu not working.
