I am lost also
Thread begun 11/03/2009 5:10 pm by marketing331920 | Last modified 11/03/2009 6:12 pm by Eric Mittman | 1562 views | 1 replies |
marketing331920
I am lost also
I just purchase the upgrade to Irite. And I have Data Assist, Security assist...I just about have all of them.
I own a 2003 Windows server with super admin / to Plesk control panel.
I also have mysql workbench...
I still do not understand how to create the database in the phpadmin.
Idea! Can I import the data / tables from the CSSform builder into mysqlworkbench and upload it to the Dreamweaver site?
If I could just get past this nemises of creating the database on the server with SOMEthing that connects to what I have purchased. This would be heaven sent. Best Regards. SValencia
I have moved this post to a new thread so that it does not get confused with the previous one.
I'm sure exactly what the trouble you are experiencing with in regards to loading the database. The CSS Form Builder tool will not edit or create any databases for you, it is just a form creation tool.
You should be able to just use your import functionality of your hosted or local environment to load the .sql files for the db. Please explain what you are trying and what the problem you are experiencing is. Also, if you have not already seen it you should take a look at the Database Starter Kit for PHP, it is a great educational piece that helps to explain a lot of the basics. Here is a link to the page it is on:
tutorials-and-training/
