strange search formatting
Thread begun 11/03/2009 12:20 pm by i.edwards384429 | Last modified 11/03/2009 6:29 pm by Eric Mittman | 1576 views | 1 replies |
i.edwards384429
Hi
starting to make progress I think...
Have the form
www.1stmodelagency.co.uk.users_registration.php
which thanks to your assistance works and uploads to the database.
I've followed the helpfiles and created a file:
search.php
if you take a look at the search page the selection boxes are weird with gaps etc
Any ideas what I've done?
thanks
Ian
It looks as though you just have some empty options on the page. When I view the source of the select lists I can see an option that has no value and no label. You can see this if you view the source, the empty options look like this:
<option value=""></option>
You just need to remove these blank entries from the select list. If the lists are dynamic then you need to check the records to ensure that there are not empty ones.
