Contact Form Not Validating Answer to Security Question
Thread begun 11/03/2009 10:06 am by don327719 | Last modified 11/04/2009 5:52 pm by Eric Mittman | 3803 views | 4 replies |
don327719
I have included the url and can attach the actual contactus.php if need be. The rest of the site was pretty easy to set up just finally stuck. The security question always comes back "Wrong Answer". I am pretty sure I am missing a setting somewhere along the way. Thanks for your help.
contactus.php
In the code on this page you should have these lines of code toward the top of the page:
if ($WAFV_Errors != "")  {
    PostResult($WAFV_Redirect,$WAFV_Errors,"contact");
Update this code so that it looks like this:
      die("the answer you posted is: " . strtolower($_POST["Security_question"]) . "<br/>the anwser it is looking for is: " . $_SESSION["random_answer"]);
When you test this page out you will see a white page that just has two messages about the security question and the answer. Please post back with what you discover.
don327719
Two line post back
the answer you posted is: saturday
the anwser it is looking for is: saturday
don327719
Two line post back - Next Step
Hi Eric, I did get the correct answers back. Any advice? Trying to finish this project up.
Based on the result you are getting this validation should not be failing. Is it possible for you to post back with this page in a zip archive? I can take a look, do some testing and add in some extra debug code to help determine why it is not working correctly. If we need to open a ticket to post private information just let me know.
