Items linked to a page 2 folder levels up do not display proper links
Thread begun 11/03/2009 7:55 am by douvan45548 | Last modified 11/03/2009 2:58 pm by Eric Mittman | 9673 views | 8 replies |
douvan45548
The horizontal menu works here:
LearningSolutions.asp
However when you click on a menu item from level 2:
IndividualEffectiveness.asp
The CSS menu doesn't link properly from the page. This appears to occur only with pages where the CSS menu item is linked to a page located 2 folder up in the file system.
neilo
In your site definitions (manage sites) - have you set linking to be relative to document or site root?
Check to make sure it is set to be relative to document.
neilo
Hi
Your (part) menu code from IndividualEffectiveness.asp looks like this:
<li class="parent link"><span class="link"><a class="link" href="../LearningSolutions.asp">Learning Solutions</a></span>
<ul class="level-1">
<li class="parent link"><span class="link"><a class="link" href="../LearningSolutions/Expertise.asp">Areas of Expertise</a></span>
<ul class="level-2">
<li class="link"><span class="link"><a class="link" href="../LearningSolutions/Expertise/IndividualEffectiveness.asp">Individual Effectiveness</a></span></li>
<li class="link"><span class="link"><a class="link" href="../LearningSolutions/Expertise/TeamEffectiveness.asp">Team Effectiveness</a></span></li>
<li class="link"><span class="link"><a class="link" href="../LearningSolutions/Expertise/OrganisationalEffectiveness.asp">Organisational Effectiveness</a></span></li>
<li class="link"><span class="link"><a class="link" href="../LearningSolutions/Expertise/SalesEffectiveness.asp">Sales Effectiveness</a></span></li>
<li class="link"><span class="link"><a class="link" href="../LearningSolutions/Expertise/LeadershipEffectiveness.asp">Leadership Effectiveness</a></span></li>
</ul>
In the level 2 menu links, the '../LearningSolutions/' part of the link is telling the browser to go back one directory and then look for a(nother) 'LearningSolutions' directory inside the 'LearningSolutions' directory.
So for instance, that last link takes you to:
www.insightstoronto.com/*LearningSolutions/LearningSolutions*/Expertise/LeadershipEffectiveness.asp
not:
www.insightstoronto.com/*LearningSolutions*/Expertise/LeadershipEffectiveness.asp
douvan45548
Originally Said By: neilo
  Hi
</ul>
not:
You have described the problem perfectly. This is what I am trying to fix. Of course I'm still looking for the solution. The problem occurs only when you are on one of the second level directory pages and are trying to use the menu.
The whole site uses the same SSI file:
upnav.htm
Why does the menu fail to function only when displaying pages which are 2 folder levels up as linked from the menu?
neilo
Hi douvan45548,
From the code of your menu includes file:
<li><span><a href="../LearningSolutions/Expertise/IndividualEffectiveness.asp">Individual Effectiveness</a></span></li>
<li><span><a href="../LearningSolutions/Expertise/TeamEffectiveness.asp">Team Effectiveness</a></span></li>
<li><span><a href="../LearningSolutions/Expertise/OrganisationalEffectiveness.asp">Organisational Effectiveness</a></span></li>
<li><span><a href="../LearningSolutions/Expertise/SalesEffectiveness.asp">Sales Effectiveness</a></span></li>
<li><span><a href="../LearningSolutions/Expertise/LeadershipEffectiveness.asp">Leadership Effectiveness</a></span></li>
Presumably the code as written to html here has '../LearningSolutions/' because the menu is situated in the 'incl_files' directory and therefore needs to refer to directories one level higher than itself. So this code works fine directly from the upnav.htm includes file.
However, when the code is written to html in the actual page that contains the include, then that same code will direct wrongly (as if it is linking from the 'incl_files/upnav.htm' pafe, not the currently loaded page).
Not sure if I've explained my thinking too well here. The only thing I can think of while keeping this as an include file, is (against my earlier advice) to make all links relational to site root, or use absolute paths in the links.
douvan45548
  Hi douvan45548,
Neilo,
Thanks again for trying. The problem is still unresolved.
The flaw in this logic is as follows:
The menu code works fine in the same directory as the include file, it also worlds one level above. It simply does not work two levels above.
neilo
Hi douvan45548
<ul class="level-0" id="cssmw">
<li><span><a href="#">Home</a></span></li>
<li class="parent"><span><a href="../LearningSolutions.asp">Learning Solutions</a></span>
<li class="parent"><span><a href="../LearningSolutions/Expertise.asp">Areas of Expertise</a></span>
Yes, odd. Looks like it's getting the level-0 items correct (../LearningSolutions.asp) but not the level-1+
Absolute paths or rel to site root may be the easiest solution. Hope you post back when you solve it! Sorry couldn't help.
I have opened a ticket for you on this issue, please login to the site and visit your support history to update the ticket.
neilo, I accidentally opened one for you on this topic, you can just close it.
douvan45548
Thanks for your suggestion.
The site definition was set to be relative to document.
Do you have any other solutions?
