Form Insert Prior to add of Captcha
Thread begun 11/03/2009 7:22 am by rog4679 | Last modified 11/03/2009 12:33 pm by Jason Byrnes | 1502 views | 1 replies |
rog4679
Hello -
I built a form 'contact Us'. I tested the 'insert record behavior' before adding CSS Form Builder. Form works without CSS Form Builder.
The server behaviors prior to form builder -
-ecart session variable - uses recordset below as primary key
-recordset conForm - uses id_primary key from bindings
-insert record
-list of fields to 'post'
After inserting Form Builder w/captcha. The form doesn't insert.
Should I remove any of the above server bindings/server behaviors prior to inserting CSS Form?
I'm not clear on sequence of bindings and server behavior.
Could you give me some direction on the process?
Thank you - Kathi
No, none of the server should need to be removed before adding captcha.
Please send a copy of the page so I can look at the code.
