Session Timeout
Thread begun 11/03/2009 6:58 am by pc316991 | Last modified 11/04/2009 9:58 am by Jason Byrnes | 4341 views | 3 replies |
pc316991
Session Timeout
I am using Securirty Assistant to handle my login and creation of session variables but users are getting logged out too soon. Is there a way that I can extend the session variable timeout period?
you need to modify the php.ini file.
See the following thread on the www.webmasterworld.com forums for more specifics:
12812.htm
pc316991
I am not running PHP. It is on a Windows 2003 server running ASP.
For asp, you can use the Session.Timeout property:
Session.Timeout = 45
to make this application wide, you may want to create a global.asa file at the root of your site with the following:
<script language="vbscript" runat="server">
sub Session_OnStart
end sub
</script>
See the following for more on the glbal.asa file:
asp_globalasa.asp
and the following for more on the session.timeout property:
prop_timeout.asp
