eCart Object
Thread begun 4/20/2009 5:14 pm by robert222776 | Last modified 4/21/2009 7:05 am by Ray Borduin | 2173 views | 1 replies |
robert222776
eCart Object
Do the column headings in my MySQL database need to correspond exactly to the eCart Object columns? For example, I have a priceCase and a priceBottle, and an itemID and a prodID (the primary key). So I assume I need to add these to the object columns? or edit the existing names?
Also, when I create a new column in the eCart object, and then try to enter it in the name field in the calculations area of the object, it will not let me saying "repeat column names are not allowed." Is this a bug?
Thanks,
Robert
No column names do not have to correspond, you can use your existing database.
This is not a bug. If you define it as a calculation it becomes a column as well. So don't define it as a column if you want to define it as a calculation.
