PCI Hosting
Thread began 11/03/2009 3:18 am by keith377536 | Last modified 11/03/2009 9:50 am by Jason Byrnes | 1601 views | 2 replies |
keith377536
PCI Hosting
Does any one know if Digital File Pro will work on PCI compliant hosting?
The problem I am having is that when a file is uploaded the file permisions are set to 600!
I have already set the folder to 755 and also tryed 777, Im not sure how to solve this isue.
Office Guy-172461
You don't say what error you're getting but I would check the ownership of the folder as well. Where is the folder located?
Hard to tell what's going on with so little information.
You can add a chmod() command after the file is uploaded, send a copy of your upload file and I will give you an example of the code needed.
