textarea collapses over other form elements
Thread begun 10/31/2009 5:07 pm by C Claypool | Last modified 11/01/2009 8:32 am by neilo | 2504 views | 3 replies |
C Claypool
Hi All
Hi have a form
feedback.php
where on a variety of platforms it works fine, and on others, the textarea (comments) collapses upwards and covers a bunch of elements including it's own label.
Any ideas on how to keep the text area where it should be?
neilo
Hiya,
Which combination of platform/browser are you seeing this problem with?
Can't reproduce this problem so far.
C Claypool
I'm sorry, I should have said it in the post ...
I was using the browsershots.org site and the screenshots I attached have the browser info in the name ...
Specifically, (the one my client uses!) Firefox 3.0 and earlier (3.1 and higher work as expected).
Surprisingly, IE doesn't cause issues (even older versions)
Navigator seems to cause problems
Opera and Safari seem okay
and the less common browsers (that I understand are built on some of the same code as FireFox like Flock and Seamonkey cause issues
neilo
Hiya,
The problem is being caused by the 'common.reset.css' in your includes/styles folder. This is a generic CSS stylesheet which is designed to reset all borders, margins etc. to zero for body, paragraph, div, table, form elements etc across all platforms and browsers. This is fine for modern browsers, but screws up older (and apparently some fairly modern) browser css. It is causing the margins created by the form builder to be set to zero, and consequently - in some browsers - you will get the 'collapse' you are seeing.
To test this, in your <head> section, replace:
<link href="../_includes/styles/screen.css" rel="stylesheet" type="text/css" />
with
<link href="../_includes/styles/p7csslm01.css" rel="stylesheet" type="text/css" />
<link href="../_includes/styles/p7PMMh13.css" rel="stylesheet" type="text/css" />
<link href="../_includes/styles/screen.layout.css" rel="stylesheet" type="text/css" />
(The 'screen.css' merely imports those three stylesheets plus the 'common.reset.css').
There are various common reset css files out there* in the www, all of them slightly different. I don't think you need one in this case.
Try the above and retest your site as before. Let us know how you get on.
* a-killer-collection-of-global-css-reset-styles/
Also see: 'Is your CSS reset doing more harm than good?' [ create-custom-css-reset ]
