Google Map PROBLEM..
Thread begun 10/31/2009 4:16 pm by chaniausedcars387440 | Last modified 11/03/2009 10:43 am by Jason Byrnes | 2653 views | 3 replies |
Hi, the google map is not working with the adress that i put in global.php, any idea. Thanks.
Can you post a link so I can see the problem?
Map problem link
AboutUs.php
I AM FROM GREECE, THANKS A LOT.
the google maps geocoder does not understand the address you are entering.
If I go to:
maps.google.com/
and enter the address you are using in the search string:
ΣΚΑΛΙΔΗ 30, ΧΑΝΙΑ, ΚPΗΤΗ, 73100, ΕΛΛΑΔΑ
google reports that it does not understand this address.
