For two days no longer works
Thread begun 10/31/2009 4:01 am by maurizio.melandri390100 | Last modified 11/05/2009 8:58 am by Jason Byrnes | 4613 views | 8 replies |
The map before it worked, I have not changed the page, now no longer works. Why?
This is page:
dovesiamo.php
anonymous
Not sure when you deployed the map, but there was a change to the Google Maps API that could be, perhaps, your issue.
See this thread here: showthread.php?t=6438
I would look at re-deploying the map to ensure the latest API and then see if the problem still exists.
Best regards,
Brian
In the siteassistpro_css/content.css file, remove the overlow: auto property from the "html, body, div, span, applet, object, iframe, h1, h2, h3, h4, h5, h6" selector, this is causing the problem:
html, body, div, span, applet, object, iframe, h1, h2, h3, h4, h5, h6 {
margin: 0;
padding: 0;
border: 0;
outline: 0;
font-size: 100%;
/*overflow:auto;*/
margin: 0;
padding: 0;
border: 0;
outline: 0;
font-size: 100%;
/*overflow:auto;*/
I made the correction. On the web, the map can be seen, but that's the map of Palo Alto. On my PC, I use XAMPP, I see the map correctly. With IE7 not seen the pictures of the menu (only on this page).
you are using the map js file from this thread:
it is only needed for power store maps, your is not a power store map.
You need to recreate the map and enter your address.
Now Adress is ok, but menu no, only in this page the menu dont work :(
The problem is caused by the period before the doctype tag at line 1:
.<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
For proper CSS Support in IE, there cannot be anything before the doctype tag on your page.
Sorry, i dont see the period :( now work well
no worries, glad to hear it is working.
