Help with search
Thread begun 10/30/2009 4:11 pm by brobert123392308 | Last modified 11/03/2009 1:50 pm by Jason Byrnes | 5356 views | 9 replies |
brobert123392308
Help with search
I hope someone can help me with issues using D/A on creating a simple search form.
I think these products are amazing with what I have done with them so far. It must be that I'm not understanding this part.
So here goes. Im using D/W cs4, mysql, php. I have D/A and DFP, My db has about 12 columns that I need to have a search page to search about 3 fields, primarily a date range, a "country" column, and maybe one more.
I have used the D/A search wizard many times and nothing happens when you hit submit but a blank page comes up.
Using the D/A wizard creates the pages but nothing happens when the submit button is hit.
I have read all the documentation I can find and it just doesnt work.
Can someone assist me, I have to launch this site Wednesday and everything else works great but this.
If you are getting a blank page, then it means a php error is occurring, but error reporting is turned off.
Add the following to line 1 of the page to turn error reporting on:
error_reporting
(E_ALL);
as for the page created by the wizard not working, I would need to see the code on the search and results page to see what is wrong.
brobert123392308
thanks Jason
Thanks for the reply Jason, I will be back on Monday to deal with the issue. I hope you can help me out then, I will post the code then.
Thank you and have a good weekend
Robert
OK, you too.
brobert123392308
Help with search
Hi Jason, here is the code for the search page for the date range. Can you tell me what I need to do to get this functional? This page has 2 text fields and a submit button.
thanks
Robert
//WA Database Search Include
require_once("WADbSearch/HelperPHP.php");
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: Recordset1;
//Searchpage: searchagain.php;
//Form: form1;
$WADbSearch1_DefaultWhere = "";
if ((isset($_POST["WADbSearch1"])) && ($_POST["WADbSearch1"] != "")) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
$KeyArr0 = array("id", "last_name", "first_name", "primary_email", "secondary_email", "city", "county", "state_us", "province_ca", "country", "event_country", "event_state_us", "event_province_ca", "event_city", "event_county", "short_description", "long_description", "_shape");
//comparison list additions
$WADbSearch1->keywordComparison($KeyArr0,"".((isset($_POST["search"]))?$_POST["search"]:"") ."","AND","Includes",",%20","%20","%22","%22",0);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_searchagain"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_searchagain"]) && $_SESSION["WADbSearch1_searchagain"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_searchagain"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
<?php require_once('Connections/connNids.php'); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_connNids, $connNids);
$query_Recordset1 = "SELECT * FROM Report";
setQueryBuilderSource($query_Recordset1,$WADbSearch1,false);
$Recordset1 = mysql_query($query_Recordset1, $connNids) or die(mysql_error());
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
$totalRows_Recordset1 = mysql_num_rows($Recordset1);
<head>
<link href="mystyles.css" rel="stylesheet" type="text/css" />
</head>
<body>
<form id="form1" name="form1" method="post" action="searchagain.php">
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>
<label>Between
<input type="text" name="Between" id="Between" />
</label>
&nbsp;
<label>And
<input type="text" name="And" id="And" />
</label>
</p>
<p>&nbsp;
&nbsp;
&nbsp;
&nbsp;
&nbsp;
&nbsp;
&nbsp;
&nbsp;
&nbsp;
&nbsp;
&nbsp;
&nbsp;
&nbsp;
&nbsp;
&nbsp;
&nbsp;
&nbsp;
&nbsp;
&nbsp;
&nbsp;
&nbsp;
&nbsp;
&nbsp;
&nbsp;
<label>
<input type="submit" name="Submit2" id="Submit2" value="Submit" />
</label>
&nbsp; </p>
<table cellpadding="2" cellspacing="0" border="0">
<tr>
<td align="center"><input type="hidden" name="WADbSearch1" value="Submit" /></td>
</tr>
</table>
</form>
</body>
</html>
mysql_free_result($Recordset1);
the dataassist search behavior is set to use a form element named search:
$WADbSearch1->keywordComparison($KeyArr0,"".((isset($_POST["search"]))?$_POST["search"]:"") ."","AND","Includes",",%20","%20","%22","%22",0 );
that does not exist in your form.
brobert123392308
new one
OK Jason,
I recreated the form as below, why can't I get any results to show up?
thanks for your help
error_reporting(E_ALL);
//Searchpage: dbsearch.php;
//Form: form1;
$KeyArr0 = array("id", "submittedDate", "state_us", "province_ca", "country", "event_date", "event_country", "event_state_us", "event_province_ca", "short_description", "long_description", "_fivehundfeet");
if (1 == 1) {
$_SESSION["WADbSearch1_dbsearch"]=$WADbSearch1->whereClause;
else {
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_dbsearch"]) && $_SESSION["WADbSearch1_dbsearch"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_dbsearch"];
else {
else {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
<head>
</head>
<body>
<form id="form1" name="form1" method="post" action="dbsearch.php">
<label>search
<input type="text" name="search" id="search" />
</label>
<label>submit
<input type="submit" name="submit" id="submit" value="Submit" />
</label>
<tr>
</tr>
</table>
</form>
</body>
</html>
please post a link so I can investigate.
brobert123392308
a link?
You want a link to the site? It's not public yet, can I send it private?
OK, I have created a support ticket so you can send the link.
supporthistory.php?
