Fatal error: Call to a member function ClearCart
Thread begun 10/30/2009 4:11 am by tim.wolak331163 | Last modified 10/30/2009 1:20 pm by Jason Byrnes | 4442 views | 7 replies |
tim.wolak331163
For some reason on the checkout success page I'm getting this error at the bottom of the page.
Fatal error: Call to a member function ClearCart() on a non-object
How do I fix this and what is the best way to clear a session after the user checks out?
Thanks,
Tim
Most likely, the success page is missing the require_once line to attach the cart include file, but I cant say for sure without seeing the code.
make sure code similar to the following is at the top of your page:
//WA eCart Include
require_once("WA_eCart/$<Cart Name>_PHP.php");
$<Cart Name>->GetContent();
Where <Cart Name> is the name of your eCart object.
To clear a session variable add :
<?php if($_SESSION['variable_name']) unset($_SESSION['variable_name']); ?>
tim.wolak331163
Here is the page, please let me know what you find.
tim.wolak331163
//WA eCart Include
require_once("WA_eCart/BNB_PHP.php");
?><?php
$BNB->GetContent();
if ($BNB->IsEmpty()) {
$BNB->redirStr = "bnb-cart.php";
$BNB->cartAction = "RedirectIfEmpty";
// WA eCart Redirect
if ($BNB->redirStr != "") {
header("Location: ".$BNB->redirStr);
<p class="eC_SmallPrint">Lorem ipsum dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat, sed diam voluptua. At vero eos et accusam et justo duo dolores et ea rebum. Stet clita kasd gubergren, no sea takimata sanctus est Lorem ipsum dolor sit amet.</p>
</div><!-- InstanceEndEditable --></div> <!-- content div end -->
</div> <!-- wrapper div end -->
<div id="footer">
</div> <!-- footBar div end -->
</body>
<!-- InstanceEnd --></html>
// Clear carts contents
$eCart1->ClearCart();
$_SESSION['clientsID'] = '';
$_SESSION['orderID'] = '';
if ("" == ""){
// WA_ClearSession
$clearAll = TRUE;
$clearThese = explode(",","");
if($clearAll){
foreach ($_SESSION as $key => $value){
unset($_SESSION[$key]);
else{
foreach($clearThese as $value){
unset($_SESSION[$value]);
tim.wolak331163
Strange also I'm seeing a lot of the same order numbers and the sessions are not ending. Any ideas?
Thanks,
Tim
The code to clear the cart:
is using a cart named eCart1, your cart is named BNB. the code should be:
$BNB->ClearCart();
Try using this code instead:
// Initialize the session.
// If you are using session_name("something"), don't forget it now!
@session_start();
// Unset all of the session variables.
$_SESSION = array();
// If it's desired to kill the session, also delete the session cookie.
// Note: This will destroy the session, and not just the session data!
if (isset($_COOKIE[session_name()])) {
setcookie(session_name(), ''time()-42000'/');
// Finally, destroy the session.
session_destroy();
tim.wolak331163
Thanks Jason, I will put that code in for sure. Any reason I would be seeing duplicate order numbers? If the sessions are not ending is that why I would be seeing things like my shipping quotes not changing when a user adds more items with more weight?
Thanks,
Tim
The order numbers are based on the session, if the session does not end, it will use the same order number.
The shipping is calculated when the checkout page posts to the confirm page.
If the user goes back and enters more items, the shipping will not be re calculated until they go through the checkout page again.
