write sql to expire records on a results page using dataassist search
Thread begun 10/29/2009 3:45 pm by JBWebWorks | Last modified 10/30/2009 2:06 pm by Jason Byrnes | 4700 views | 3 replies |
JBWebWorks
want items to expire 60 days after posting
here is the Recordset that i have
SELECT *,DATE_FORMAT(items.item_listed, '%b %e, %Y') AS theDate
FROM items INNER JOIN accounts ON items.account_ID = accounts.account_ID
WHERE items.category_ID = var1 AND items.item_listed>= CURDATE() - INTERVAL 60 DAY
ORDER BY items.item_listed DESC
Using dataassist search
code is
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$currentPage = $_SERVER["PHP_SELF"];
$maxRows_rs_itemcat = 10;
$pageNum_rs_itemcat = 0;
if (isset($_GET['pageNum_rs_itemcat'])) {
$pageNum_rs_itemcat = $_GET['pageNum_rs_itemcat'];
$startRow_rs_itemcat = $pageNum_rs_itemcat * $maxRows_rs_itemcat;
$var1_rs_itemcat = "-1";
if (isset($_GET['item_cat_ID'])) {
$var1_rs_itemcat = (get_magic_quotes_gpc()) ? $_GET['item_cat_ID'] : addslashes($_GET['item_cat_ID']);
mysql_select_db($database_connbubba, $connbubba);
$query_rs_itemcat = sprintf("SELECT *,DATE_FORMAT(items.item_listed, '%%b %%e, %%Y') AS theDate FROM items INNER JOIN accounts ON items.account_ID = accounts.account_ID WHERE items.category_ID = %s AND items.item_listed>= CURDATE() - INTERVAL 60 DAY ORDER BY items.item_listed DESC", GetSQLValueString($var1_rs_itemcat, "int"));
setQueryBuilderSource($query_rs_itemcat,$WADbSearch1,false);
$query_limit_rs_itemcat = sprintf("%s LIMIT %d, %d", $query_rs_itemcat, $startRow_rs_itemcat, $maxRows_rs_itemcat);
$rs_itemcat = mysql_query($query_limit_rs_itemcat, $connbubba) or die(mysql_error());
$row_rs_itemcat = mysql_fetch_assoc($rs_itemcat);
if (isset($_GET['totalRows_rs_itemcat'])) {
$totalRows_rs_itemcat = $_GET['totalRows_rs_itemcat'];
} else {
$all_rs_itemcat = mysql_query($query_rs_itemcat);
$totalRows_rs_itemcat = mysql_num_rows($all_rs_itemcat);
$totalPages_rs_itemcat = ceil($totalRows_rs_itemcat/$maxRows_rs_itemcat)-1;
$queryString_rs_itemcat = "";
if (!empty($_SERVER['QUERY_STRING'])) {
$params = explode("&", $_SERVER['QUERY_STRING']);
$newParams = array();
foreach ($params as $param) {
if (stristr($param, "pageNum_rs_itemcat") == false &&
stristr($param, "totalRows_rs_itemcat") == false) {
array_push($newParams, $param);
if (count($newParams) != 0) {
$queryString_rs_itemcat = "&" . htmlentities(implode("&", $newParams));
$queryString_rs_itemcat = sprintf("&totalRows_rs_itemcat=%d%s", $totalRows_rs_itemcat, $queryString_rs_itemcat);
i have tested and no matter the if the INTERVAL is only 1 day, the item still shows up
thanks for your help,
jim balthrop
this:
is saying where item listed is greater than or = 60 days ago
you want less than or equal 60 days ago:
items.item_listed<= CURDATE() - INTERVAL 60 DAY
JBWebWorks
I want the item to not display if it is more than 60 days since posting, so if it is greater than 60 days ago it will show, when the current date less 60 days is more than the posting date, the item is expired and will not display.
I could not get it to work with the dataAssist search, so i rewrote the sql to this and it works like i want.
WHERE items.item_title LIKE %var1% AND items.item_listed>= CURDATE() - INTERVAL 60 DAY OR items.item_description LIKE %var1% AND items.item_listed>= CURDATE() - INTERVAL 60 DAY
var1 is $_POST['searchbox']
OK, glad to hear it is working
