MySQL Query Browser can't connect to MySQL Serve
Thread begun 10/29/2009 1:29 pm by karenamck240415 | Last modified 10/30/2009 9:37 am by Jason Byrnes | 6908 views | 4 replies |
karenamck240415
I am using the MySQL Query Browser for the first time and trying to get through the PowerCMS instructions under "Using MySQL Query Browser". I have no idea what to do, I keep getting error 1045.
The using phpMyAdmin step went fine.
the error 1045 means the user name and password you are entering is not correct.
Are you trying to connect to a local mySQL Server or a remote MySQL Server?
If it is a local MySQL Server, set the Host name to Localhost.
if it is a remote MySQL Server, you will need to find out from your host a few things, 1) Do they allow remote connections to the MySQL server 2) what is the mySQL Server address to use.
karenamck240415
I know the user name and pass word are incorrect but I have tried all the what are suppose to be the correct ones
it is a local server and I have tried localhost and 127.0.0.1
karenamck240415
I figured this out but now I don't know what the .sql file I need to import is. It appears to be a user table. Was that provided by PowerCMS?
the CMS.sql file is in the Database folder of the PowerCMS files.
