Insert two footer
Thread begun 10/29/2009 1:14 pm by massimo173451 | Last modified 10/30/2009 4:33 pm by Jason Byrnes | 4016 views | 5 replies |
massimo173451
Insert two footer
Hi there,
I need to insert two footer in my page, after insert it the final effect is the follow, note on top copyright text the color difference. May you explain me why this happen and if is possible edit this CSS page with CSS Sculptor (I have imported the original file from Template Product in the CSS Sculptor then edit it in DW for insert two footer)?
Massimo
It is impossible to tell what is causing that color band from the picture.
please post a link where I could see the problem in a browser.
massimo173451
Hi Jason,
Here the link for the issue homepage.asp
Regards:
Massimo
this page does notlook anything like your screen shot,
One thing I see wrong when viewing the source, is the path to the css files:
<style type="text/css" media="all">
@import url("file:///C|/Inetpub/wwwroot/tessyacconciature/CSSSculptor/Products_NewDesign_css/screen.css");
</style>
<style type="text/css" media="print">
@import url("file:///C|/Inetpub/wwwroot/tessyacconciature/CSSSculptor/Products_NewDesign_css/print.css");
</style>
should be:
@import url("CSSSculptor/Products_NewDesign_css/screen.css");
</style>
@import url("CSSSculptor/Products_NewDesign_css/print.css");
</style>
massimo173451
Hi Jason, thank you for your answer but the color difference is visible with IE 8, I haven't tried with other browser. I suppose there is something wrong when I have created the second footer (one for text Copyright and the other one for shortcut menu'). This CSS works fine only with one footer (I have used it in other pages with best result).
The probliem is caused by the background image applied to the footer1 class:
background-image: url(../../Products_images/footer_bg.jpg);
Remove that background image.
