Dynamic Drop Down Problem
Okay, here is here I'm stuck at now...
My "business type" and "state" drop down appears correctly along with the "add to list" and "remove" buttons but my "fee" field does not! How can I get the fee to appear?
[Select Business] working
[Select State] working
[need this to be a text field to display a fee] But it is being populated with the "state" not the "fee"
[Add to List] working
[Remove] working
<form id="form1" method="post" action="">
<p>
<select name="parent" size="1" id="parent" onchange="WA_FilterAndPopulateSubList(Child_WAJA,MM_findObj('parent'),MM_findObj('child'),0,0,false,': ')">
do {
<option value="<?php echo $row_Parent['ParentID']?>"><?php echo $row_Parent['BusinessEntity']?></option>
} while ($row_Parent = mysql_fetch_assoc($Parent));
$rows = mysql_num_rows($Parent);
if($rows > 0) {
mysql_data_seek($Parent, 0);
$row_Parent = mysql_fetch_assoc($Parent);
</select>
<select name="child" size="1" id="child" onchange="WA_AddSubToSelected(MM_findObj('child'),MM_findObj('target'),false,false,false,0,0,'0','')">
</select>
<select name="target" size="1" id="target">
</select>
<input name="add" type="button" id="add" onclick="WA_AddSubToSelected(MM_findObj('child'),MM_findObj('target'),false,false,false,0,0,'0','')" value="Add to Cart" />
<input name="remove" type="button" id="remove" onclick="WA_RemoveSelectedFromList(MM_findObj('target'),'|WA|0|WA|',-1,'0','None Selected')" value="Remove" />
</p>
</form>
