Search %LIKE% with leading & trailing spaces
Thread begun 10/28/2009 8:46 am by David CHnet.com | Last modified 10/29/2009 10:14 am by Jason Byrnes | 3663 views | 5 replies |
David CHnet.com
I'd like to do a search on a description field, for example looking for the word "sea", but I don't want to see results such as "research", only those that match " sea " as an isolated word surrounded by spaces.
I can fix most things on my own, but this is driving me a bit nuts!
Any help anyone please?
Here is the related code ...
Thanks!
==================== CODE ===========================
$KeyArr1 = array("w_desc");
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_POST["descriptionSearch"]))?$_POST["descriptionSearch"]:"") ."","AND","Includes",",%20","%20","%22","%22",0);
try using:
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_POST["descriptionSearch"]))?"nbsp;".$_POST["descriptionSearch"]."nbsp;":"") ."","AND","Includes",",%20","%20","%22","%22",0 );
this will add a leading and trailing space to the search term.
David CHnet.com
Almost ...
Hi Jason, and thanks.
I tried your code and get zeo data. I added the & before the nbsp; but with or without I still get zero.
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_POST["descriptionSearch"]))?" ".$_POST["descriptionSearch"]." ":"") ."","AND","Includes",",%20","%20","%22","%22",0 );
Can you cast another eye over it please?
Thanks,
David
OK, I got this working, but I needed to do these 2 things:
1) Add the literal space instead instead of the html entity
2) change the OR Separator from a space to the pipe symbol:
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_POST["descriptionSearch"]))?" ".$_POST["descriptionSearch"]." ":"")  ."","AND","Includes",",%20","|%20","%22","%22",0);
David CHnet.com
Working
Thanks Jason, that works perfectly :)
David
You're welcome.
