DFP will not upload or show progress bar
Thread begun 10/28/2009 5:13 am by carlos311519 | Last modified 10/29/2009 11:43 am by Francois | 4356 views | 5 replies |
carlos311519
On the page (sm_custom.php) I am using DFP to upload an image to a folder on my server named "upload". I also installed the progress bar to show progress of the file being uploaded. For some reason the file is not being uploaded to the server nor is the progress bar showing.. please advise...??
anonymous
Carlos,
Could you post the code on here for inspection?
Brian
carlos311519
Here is my code....
i attached the code in a txt file
The first problem I see is that the forms encoding type is not set to mulipart/form-data
change:
html:
<form id="xl_form" method="post" action="">
html:
<form action="" method="post" enctype="multipart/form-data" id="xl_form">
If your still having problems after changing the encoding type, add the following at line 1 to see if a php error is occurring:
error_reporting
(E_ALL);
and on the bindings panel, expand the WA Uploaded Files Global Status group and add the Debug Info binding to the page. Post back the debug info after trying to upload a file.
carlos311519
That fixed it
I was trying everything, usually that field is already populated with that information, its the little things that drive you crazy... thanks for the help
Francois
had same problem and solved
It turns out, for me, that I had an upload file on my site before, and some files where not replaced with new ones. I deleted the files in the WA_DigitalFilePro and reconfigured the WA Upload Files on the page. Uploaded all new files to server and it worked after that. Hope it helps you.
