Center hover .jpg disappearing
Thread begun 10/28/2009 3:58 am by pieter.perma_awnings389909 | Last modified 10/28/2009 12:00 pm by Jason Byrnes | 2101 views | 3 replies |
I added a menu item and after updating my files I found that in the live mode and on the website live the center .jpg on hover disappeared. It is as if the repeat function does not work and or as if it is blocked from loading and I only get a white block between the left and right image jpg's on hover. This has happend once before and I had to rebuild the entire menu but is there an easier way? Your input will be appreciated as rebuilding the menu will be a time consuming process.
could you post a link so I can take a look at the css.
www.permawnings.com
In the menu writer mode when one clicks on the "apply button" and then click on the box for the image which take you to a live view on a browser the hover button is correct but once posted to my site it does not work again. As if center.jpg is not loaded and/or repeat is none.
in the screen.css file, remove the background-color: #fff attribute from the html, body, div, span, applet, object, iframe, h1, h2, h3, h4, h5, h6 { selector:
margin: 0;
border: 0;
outline: 0;
font-size: 100%;
/*background-color: #FFF;*/
