Potential bug?
Thread begun 10/27/2009 7:53 pm by twitchr377598 | Last modified 10/28/2009 11:21 am by twitchr377598 | 2082 views | 3 replies |
twitchr377598
Potential bug?
I did a quick search of the forum and didn't see an answer for this. Hope I'm not repeating a known issue.
I have been working on a backend administration control panel most of the day and I got around to coding the update page and think there is a bug in Digital File Pro. Not sure if it's a bug new to 2.0.2 cause this is my first time using it.
I noticed that if I updated a record without uploading a file, that field in the database would be empty so I tried to troubleshoot and I noticed something. When I open up my upload file server behavior and set the Default file to my hidden field and click ok, I open the upload file server behavior again and the default file field is blank. It doesn't seem to be saving that setting.
Anyone else having this issue.
I'm using Digital File Pro 2.02. with Dreamweaver CS3
Thanks,
Twitch
anonymous
Twitch,
There was a bug with the first release but that should be fixed with the latest dot release... one thing I have had to do a couple of times is press the tab or return key after setting the default file to ensure that it sets in the dialog box. If you cannot get it to work, you could edit the default file property manually, inside the code. But again, try updating it again and hitting either tab or enter inside the input box and see what happens.
Regards,
Brian
After selecting the hidden form field, use the keyboards enter key before clicking the OK button in the DFP Wizard to force the selection to stick.
twitchr377598
Jason and Sojo, thanks so much for the replies. Hitting return did the trick! Now I'm rocking and rolling.
Much appreciated guys. My extreme satisfaction with my WebAssist subscription continues.
-Twitch
