USPS International Priority
Thread begun 10/27/2009 10:14 am by courtyo | Last modified 10/28/2009 10:22 am by Eric Mittman | 1949 views | 1 replies |
courtyo
I need to calculate International Priority Mail for international orders but do not see it listed as an option. I hand-coded in PRIORITY as the international choice but am not getting the right amount. Amount should be $26.50 and I am getting $6.28 (first class price).
In the Full Response I do see that USPS returned the price for Priority Mail International ($26.50), so the error appears to be in how the information is being called by the script.
Here is the code I used:
$Shipping_Parameters["CarrierCode"] = "PRIORITY";
$Shipping_Parameters["DefaultIntl"] = "PRIORITY";
What should I list for DefaultIntl to call the correct Priority Mail International shipping amount?
The way the shipping charge rules are designed you should have a shipping charge that is equal to the quote returned from USPS. If you can see the full response and the amount differs from the charge you see in the cart then the problem may not be the API interaction that is occurring.
To check this take a look at your shipping rule and ensure that it is set to just use the value of the quote for the charge. If it is setup this way then we will need to look more closely at the api interaction and where the values are going. Please confirm the details of your shipping rule and if needed I will open a ticket on this so we can investigate it further.
