Broken Links inside .css/admin.css
Thread begun 10/27/2009 8:35 am by latellogroup375248 | Last modified 10/27/2009 12:53 pm by latellogroup375248 | 5861 views | 11 replies |
latellogroup375248
I am getting broken link errors about certain images. But when I open the document it all appears to be ok. There are about 5 or 6 of them. Here is one example:
File Broken Link
.css/admin.css ../Images/admin/formBoxWrapper_bg.png
Is there a special way to fix this. I have already tried opening the file folder by the "Broken Link" and redirecting it but the errors still persist. I have also tried opening the actual file in code view and redoing the link there and it does not change anything. Thanks in advance for your help.
"Future Expert in Training"
Office Guy-172461
WA_Globals.php file settings
Sounds like something's wrong in your Globals file.
Have a look here:
178/
latellogroup375248
First thanks for the help. I read the link and it appears to me that everything is correct. But if you could take a look at this and tell me anything jumps out at you that would be great.
$WAGLOBAL_Root_URL = "http://www.livingtrue2me.com/" ;
$WAGLOBAL_Site_Name = "LivingTrue2ME" ;
$WAGLOBAL_Address = "";
$WAGLOBAL_City = "";
$WAGLOBAL_State = "";
$WAGLOBAL_Zip = "";
$WAGLOBAL_Country = "US";
$WAGLOBAL_GoogleAPIKey = "";
$WAGLOBAL_localRoot = "livingtruestore.db.5145779.hostedresource.com";
$WAGLOBAL_remoteRoot = "/";
Office Guy-172461
Your local root doesn't look right.
I think you want:
$WAGLOBAL_localRoot = "/";
latellogroup375248
Thank you very much Neilo. I will check this now and update you asap. This makes perfect sense.
Office Guy-172461
Not sure now about the localroot. Are you using a remote testing server?
neilo
Check all the links in your .css stylesheets ( admin.css and common.css)
The links to images all point to Images/... not images/...
Office Guy-172461
Easy way to do that:
151/
Then run the link checker.
neilo
Blimey - all these years using DW and I never noticed that checkbox. Nice one (again)!
Office Guy-172461
I'm still looking for the Fix All Errors checkbox. Let me know if you find that one. :)
