Add To Cart Button Not Working
Thread begun 10/27/2009 8:25 am by latellogroup375248 | Last modified 10/27/2009 4:18 pm by latellogroup375248 | 45224 views | 18 replies |
latellogroup375248
Since I have loaded up to my server and gone live the "add to cart" button has stopped working. All it does is refresh the current page. Can someone please help give details on how to fix this error? Please be specific.Products_Detail.php?ProductID=4 Big dumb animal here learning and getting smarter everyday, LOL.
Office Guy-172461
It points to:
I think you put the path to the image instead of the link.
latellogroup375248
when i click on the image in design view in DWcs4 I see a place for the source but no place for a link. So I am not sure how I would make this link to put in the cart. Also would this button possibly supposed to be associated with a recordset? when i click on the "source" to point to a file I have to choose between "data sources" or "file system". In data sources the first thing is "Recordset (WADA Products)" when I click to open this I get this error:
MySQL Error#: 1064
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 2
Could this be the problem and if so how would I fix it?
Office Guy-172461
MySQL Reserved Words
You are probably using a reserved word.
156/
Sorry Office Guy, lets get back to the beginning on this one.
The image button is supposed to link to the image source file. It is used to submit the form. As for the recordset, it is to complex for Dreamweaver to parse so throws that error.
latellogroup,
there is probably a php error occurring when adding the item to the cart. you say it is working on your local testing server? it is only when pushed to the remote server that there is a problem?
add the following code to line 1 of your page:
error_reporting
(E_ALL);
This will display any PHP errors that may be occuring on the page.
latellogroup375248
Ok, Did this and I am getting the following error. Wanted to post it before I started looking for it Thanks
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/l/i/v/livingtrue/html/Products_Detail.php:5) in /home/content/l/i/v/livingtrue/html/WA_eCart/WA_eCart_Definition_PHP.php on line 479
The following is what is on my lines 479-482 in my "product_details.php. Couldn't tell you what is right or wrong on this one?
<div id="checkingAvail" style="display:none" > Checking availability. </div>
<div id="notSold" <?php echo(($row_WADAProducts["ProductLive"] == 0)?'':'style="display:none"'); ?> >
<div id="notSold2" <?php echo(($row_WADAProducts["ProductLive"] == 0)?'':'style="display:none"'); ?> >
<div id="notSold3" <?php echo(($row_WADAProducts["ProductLive"] == 0)?'':'style="display:none"'); ?> >This item is not available online. </div>
the error is occurring on line 4 or 5 of the product detail page:
Look for blank space after a closing PHP tag:
or a blank line between a closing php tag and an opening one:
<?php...
you may also be running into a session problem on the server. Try uploading the attached file and running it.
latellogroup375248
Thank you. I am looking and downloading now. Will update as soon as I have something new.
latellogroup375248
Ok uploaded the sessions page opened it up and clicked and the variable did not change which if I understand is good. Second found some spaces on lines 4 and 5 and deleted them. Now when i go to the products detail page there is nothing and a link at the top of the page that says: Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/l/i/v/livingtrue/html/Products_Detail.php:4) in /home/content/l/i/v/livingtrue/html/WA_eCart/WA_eCart_Definition_PHP.php on line 479
when I click on the link it gives the following error:
Not Found
The requested URL /function.session-start was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/1.3.33 Server at www.livingtrue2me.com Port 80
Am I getting better or worse????
Also should I undo any of the stuff I have done so far. I.e upload the sessions page etc.
There is still a problem at line 3 or 4, send a copy of the deail page so I can take a look at the code.
