I don't know what I'm doing
Thread begun 10/26/2009 2:32 pm by michael239810 | Last modified 10/26/2009 5:31 pm by neilo | 3522 views | 5 replies |
michael239810
My first time try at forms are not working.
I've built a few forms with the Form Builder DW plugin program. The forms are located in php pages. When I upload them and try to view them I'm getting this error:
Warning: require_once(../../../WA_ValidationToolkit/WAVT_Scripts_PHP.php) [function.require-once]: failed to open stream: No such file or directory in /home/knoxhil2/public_html/TEST/Member/index.php on line 1
Fatal error: require_once() [function.require]: Failed opening required '../../../WA_ValidationToolkit/WAVT_Scripts_PHP.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/knoxhil2/public_html/TEST/Member/index.php on line 1
I'm not a programmer, so I don't know what I'm doing wrong. Any help would be greatly appreciated.
PS: I'm working with DW CS4.
michael239810
followup
I'm not sure if I need to upload anything to make the forms work. This page seems to work put it looks like the CSS code for the form didn't upload.
support.php
michael239810
Additional information
I noticed that in the user manual it says that additional files or folders have been added, yet I didn't see any additional files or folders. I've uploaded everything to the site that's in my TEST folder.
neilo
Hi Michael,
Your page refers to a few files that it needs to function properly.
Your current code shows these:
<link href="../../../SpryAssets/SpryValidationTextField.css" rel="stylesheet" type="text/css" />
<script src="../../../SpryAssets/SpryValidationTextField.js" type="text/javascript"></script>
<link href="../../../SpryAssets/SpryValidationTextarea.css" rel="stylesheet" type="text/css" />
<script src="../../../SpryAssets/SpryValidationTextarea.js" type="text/javascript"></script>
<link href="../../../CSSFormBuilder/FD_Sharp_Default.css" rel="stylesheet" type="text/css" />
The ../../../ part of these is telling the page to look for the files in a folder that is below even your root folder - so is not correct.
Upload the folders 'SpryAssets' and 'CSSFormBuilder' to their default places on your remote site (the directories should be in the root folder) and change the links in your page to point to these files relative to your page.
If you have problems with the links, post back details of where the uploaded files have been put (in which directory - and sub-directories etc.)
michael239810
Looks like my style sheet isn't working
Here's the link:
index.php
It looks like my style sheet is not linked or something. I'm seeing all the code and it's not picking up the setting I choose for the style.
Thanks in advance for the help.
neilo
Hi Michael,
Yes - the paths to the required files seem to be wrong, as I mentioned in my last post.
<script src="../../../CSSFormBuilder/WA_ServerValidation.js" type="text/javascript"></script>
<script src="../../../CSSFormBuilder/WA_ClientValidation.js" type="text/javascript"></script>
<link href="../../../SpryAssets/SpryValidationSelect.css" rel="stylesheet" type="text/css" />
<script src="../../../SpryAssets/SpryValidationSelect.js" type="text/javascript"></script>
<script src="../../../CSSFormBuilder/WA_ShowCVV.js" type="text/javascript"></script>
Please could you have a look on your remote server and make sure that the folders 'SpryAssets' and 'CSSFormBuilder' and their contents have been uploaded, and then make the paths to required files in your page link to the right places.
Post back if you have problems.
