Universal Email Tutorial
Thread begun 10/26/2009 11:52 am by michaelf0199272 | Last modified 10/26/2009 2:12 pm by Jason Byrnes | 1849 views | 1 replies |
michaelf0199272
Q: Has there been a change to the Universal Email Online Tutorial recently?
I am asking because it is very different from when I used it as guide to appply UE to a contact form about 3-4 weeks ago.
When I revisited the UE Tutorial the portion on the BODY tab -- where you choose HTML Preview and the you click on the Edit, then you click on the Get Form File tab -- This used to create a zip file, which is the unzipped and then copied and pasted on the HTML Preprview Tab. This worked fine like a charm. Now it it simply prompts you to get the HTML_email.php from the Universal_Email Folder.
Q2: Should it not be the contact form? This is because it is the contact form that I am trying to apply EU to. Or is there a way I can get the old EU Tutorial?
Many thanks,
Michael
No, the UniversaL Email Solution recipe has not been changed.
I think you may be referring to the "Sending the form" section of the "Sending form information in an email" tutorial.
tho code from the zip file is:
<?php foreach( $_POST as $pkey => $pval ) { ?>
echo(str_replace("_"," ",$pkey).": ".($pval)); ?>
