Big image and thumb upload stopped working?
Thread begun 10/26/2009 11:52 am by olle189996 | Last modified 10/27/2009 12:30 am by olle189996 | 2617 views | 3 replies |
olle189996
Hi
I used to upload 2 images with the same filefield to two different locations.
One is the big image and one goes to the thumb folder.
I am applying the Upload Files Behavior twice on the same page.
Now this does not function anymore.
What am I doing wrong?
I can use two filefields. That is working.
But I want to have the thumb created like automatic.
Code
<?php require_once("WA_DigitalFilePro/HelperPHP.php"); ?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "images/stora/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "120",
'ResizeHeight' => "120",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End?>
// WA_UploadResult2 Params Start
$WA_UploadResult2_Params = array();
// WA_UploadResult2_1 Start
$WA_UploadResult2_Params["WA_UploadResult2_1"] = array(
'UploadFolder' => "images/small/",
'ResizeType' => "1",
// WA_UploadResult2_1 End
// WA_UploadResult2 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["button"])){
WA_DFP_UploadFiles("WA_UploadResult1", "fileField", "0", "", "JPG:80", $WA_UploadResult1_Params);
WA_DFP_SetupUploadStatusStruct("WA_UploadResult2");
WA_DFP_UploadFiles("WA_UploadResult2", "fileField", "0", "", "JPG:80", $WA_UploadResult2_Params);
Regards
Olle
olle189996
Ok, I have som updates about the problem.
If I use an older HelperPHP.php created in beginning of June. Everything works!
With new HelperPHP.php from 2.02 it does not.
I also get an error in MAMP php log
PHP Notice: Undefined variable: firstFile in Sites/hcm/WA_DigitalFilePro/HelperPHP.php on line 334
Is this how it should be?
I can upload two images to different folder of the same kind in the behavior by adding another [name] in the filefield.
But what if I want one large tif. and a small thumb jpg?
Regards
olle
Can you send a copy of your page so I can look at the code.
olle189996
Hi
Here is the files.
So, with the OLD_WA_DigitalFile ... helper file everything works.
With the new one created with 2.01 only one of the images is uploaded
Regards
Olle
