server side validation
Thread begun 10/25/2009 1:35 pm by i.edwards384429 | Last modified 10/26/2009 12:14 pm by Jason Byrnes | 2841 views | 3 replies |
i.edwards384429
Hi
trying to get my head around the server side validation used because I need to add 10 additional fields to the database.
I've used the spry widgets in the past but always client side!
Looking at the pre exisiting country field the validation is set to dynamic and is
<?php (ValidatedField("usersRegistration","UserCountry")) ?>
It seems to be getting it from a form called WAATKregistrations
Can anyone recommend a good book on server side validation because this is loosing me
thanks
Ian
The server side validation is created using the Validation Toolkit functionality of CSS Form Builder.
If CSS Form Builder is installed, go to the server behaviors panel and Click the Server Validations server behavior. You can add server side validations here.
i.edwards384429
update
thanks for that!
this learning curve is getting steeper
one day I'll be an expert ;-)
Ian
in perspective, there is the learning curve to learning ho to hand code PHP, or use tools to generate the PHP for you ;)
