HTML Editor Tutorial - Where?
Thread begun 10/24/2009 7:24 pm by neilo | Last modified 10/25/2009 12:22 am by neilo | 1836 views | 2 replies |
neilo
So I assume that as there are no support files in the HTML Editor Downloads page, that I should use those in the iRite Downloads page.
Under 'Support Resources' I can find the 'Getting Started Guide'. Under 'Solution Recipes - Support Files' I can download: 'iRite: Solution Recipe Files (4 MB)'
This gives me a downloaded zip folder containing folders: Datasources, Finish Files and Start Files.
Because of their components, I assume these are to accompany a tutorial which takes one through a scenario. Can anyone point me to one?
Thanks.
anonymous
Neilo,
Is there something specific you are trying to do? I am not sure how a tutorial would apply to HTML editor... it's something that you either choose to use or not. I will certainly be glad to help anyway possible as I have given this thing every tug and twist imaginable.
Best regards,
Brian
neilo
Thanks Brian, I appreciate that. I may well get back to you on this in due course.
At the moment I was only trying to understand why the support files for the Editor ('Solution Recipe Files' wich unzips as: 'iRite_support_files') comprised three folders, - Datasources, Finish Files and Start Files, along with the GSG which doesn't reference these folders or files. I couldn't understand why they were there.
What I may eventually need help with is in having a final last ditch attempt at getting Security Assist installed (have never been able to install it from 1.1.7 or 1.1.8). So will be backing up my machine today and having a go. I would be grateful if you could watch this space!
Cheers
