Retaining data when doing an update
Thread began 10/24/2009 1:44 pm by nancy | Last modified 10/26/2009 9:54 am by Jason Byrnes | 975 views | 1 replies |
nancy
I have successfully created Insert, Update, Results and Detail pages. I insert data using the Insert page > it displays in the Results and Detail. All good.
I have a mixture of input fields - textarea, text, radio buttons, checkboxes and files (images using DFP). When I use the update page only the textarea and text fields "echo" what is in the database, even though every field has the code to "echo".
I have to re-enter the data for the checkboxes, radio buttons and image files to get them to display after using the update page. By checking the database directly after an Update - The fields are now NULL unless I re-enter them.
It seems like I need an if statement, but the textarea and text don't need it.
What am I missing?
Checkboxes and radio buttons work a bit different from text boxes and text areas.
To dynamically set the checked state of a radio button or checkbox, you must first statically set the checked value. Then in the Property inspector, click the Dynamic Button.
Click the lightning bolt next to Check IF and select the corresponding recordset column. In the Equal to section enter the checked valuer for that checkbox.
File fields are a bit different, since they are meant to read from the clients computer, they cannot be given a value at page load.
See the "How to apply Digital File Pro to DataAssist Insert and Update pages" tutorial for instructions on how to maintain the file name from the database on update. It is available in the How To section of the Digital File Pro support page:
digital-file-pro/
