Price range search
Thread begun 10/23/2009 9:37 am by maurizio.melandri390100 | Last modified 10/28/2009 11:48 am by Eric Mittman | 6093 views | 7 replies |
Price range search
I have created with data assist a form with 2 fields for price range. Form work well, but price range not work.
I tried with data assist search but not work.
I am attaching the search and page results before and after the date assists search
Setting this up correctly in DataAssist Search you will need to have two criteria. One for the start and one for the end. For the first criteria you will select the price column, then for the type select Number, then for the comparison you will select less than. Finally for the type choose value, and for the value use the lightning bolt to select your min price field.
For the max price you would do the same thing but choose greater than for the comparison and select the max price input for the value.
What are the steps you have taken and what is the result you are getting?
I open the page of results. I run search wizard and select the search page and the search form. I add the "range of price" and select "or". I select the column of price in the table and 2 fileds (text field) from form (minimum and maximum).
When try in IE i have this error:
Fatal error: Class 'FilterDef' not found in C:\xampp\htdocs\www\doctorhousepc\lista-prodotti-cercati.php on line 10
The page lista-prodotti-cercati from line 1 thru line 87:
<?php require_once('Connections/schede.php'); ?>
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: WADAdhpc_prodotti;
//Searchpage: search.php;
//Form: WADASearchForm;
$WADbSearch2_DefaultWhere = "";
if ((isset($_GET["WADbSearch2"])) && ($_GET["WADbSearch2"] != "")) {
$WADbSearch2 = new FilterDef;
$WADbSearch2->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
//comparison list additions
$WADbSearch2->addComparison("dhpc_Prezzo","".WADS_stripCurrency($_POST["S_dhpc_Prezzo"]) ."","OR",">=",1);
$WADbSearch2->addComparison("dhpc_Prezzo","".WADS_stripCurrency($_POST["S_dhpc_Prezzo2"]) ."","AND","<=",1);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch2_listaprodotticercati"]=$WADbSearch2->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch2_listaprodotticercati"]) && $_SESSION["WADbSearch2_listaprodotticercati"] != "") {
$WADbSearch2->whereClause = $_SESSION["WADbSearch2_listaprodotticercati"];
else {
$WADbSearch2->whereClause = $WADbSearch2_DefaultWhere;
else {
$WADbSearch2->whereClause = str_replace("\\''", "''", $WADbSearch2->whereClause);
$WADbSearch2whereClause = '';
//WA Database Search Include
require_once("WADbSearch/HelperPHP.php");
$WADbSearch1_DefaultWhere = "";
if ((isset($_GET["Search_x"]) && $_GET["Search_x"] != "")) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
$WADbSearch1->addComparisonFromList("DHPC_Descrizione_tipo","S_DHPC_Descrizione_tipo","AND","=",0);
$WADbSearch1->addComparisonFromEdit("dhpc_Marca","S_dhpc_Marca","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("dhpc_Sigla","S_dhpc_Sigla","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("dhpc_Prezzo","S_dhpc_Prezzo","AND","<=",1);
$WADbSearch1->addComparisonFromEdit("dhpc_Prezzo","S_dhpc_Prezzo","AND",">=",1);
if (1 == 1) {
$_SESSION["WADbSearch1_listaprodotticercati"]=$WADbSearch1->whereClause;
else {
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_listaprodotticercati"]) && $_SESSION["WADbSearch1_listaprodotticercati"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_listaprodotticercati"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
The error you are getting about the filterdef is because you have the include further down on the page.
Move this code to the top of the page:
The other thing you mentioned was that you are using OR as the separator, you should use AND so that the results or exclusive to the rates you enter. If you have the two criteria separated by OR then you will get any results that are greater than the first value, or less than the second. You should have both criteria separated with the AND so that you will have values that are greater than the first entered value and less than the second entered value.
Other than this the code on the page looks like the search is setup correctly. Please make these updates and test the page out again to see if you are getting the desired result.
I tried again. I used both the wizard DataAssist and the wizard DataAssist search. The price range-finding fails, all other research work, but when it searches for a price range don't find any records.
this is the page of results.
if (1 == 1) {
else {
if (1 == 1) {
else {
else {
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$currentPage = $_SERVER["PHP_SELF"];
$maxRows_WADAdhpc_prodotti = 5;
$pageNum_WADAdhpc_prodotti = 0;
if (isset($_GET['pageNum_WADAdhpc_prodotti'])) {
$pageNum_WADAdhpc_prodotti = $_GET['pageNum_WADAdhpc_prodotti'];
$startRow_WADAdhpc_prodotti = $pageNum_WADAdhpc_prodotti * $maxRows_WADAdhpc_prodotti;
$WADADHPC_Descrizione_tipo_WADAdhpc_prodotti = "-1";
if (isset($_GET['DHPC_Descrizione_tipo'])) {
$WADADHPC_Descrizione_tipo_WADAdhpc_prodotti = (get_magic_quotes_gpc()) ? $_GET['DHPC_Descrizione_tipo'] : addslashes($_GET['DHPC_Descrizione_tipo']);
mysql_select_db($database_schede, $schede);
$query_WADAdhpc_prodotti = sprintf("SELECT dhpc_tipo, dhpc_Marca, dhpc_Sigla, dhpc_Descrizione, dhpc_Descrizione_lunga, dhpc_Descrizione_negozio, dhpc_Prezzo, dhpc_Foto, DHPC_Descrizione_tipo FROM dhpc_prodotti ORDER BY dhpc_Marca ASC", GetSQLValueString($WADADHPC_Descrizione_tipo_WADAdhpc_prodotti, "text"));
setQueryBuilderSource($query_WADAdhpc_prodotti,$WADbSearch1,false);
$query_limit_WADAdhpc_prodotti = sprintf("%s LIMIT %d, %d", $query_WADAdhpc_prodotti, $startRow_WADAdhpc_prodotti, $maxRows_WADAdhpc_prodotti);
$WADAdhpc_prodotti = mysql_query($query_limit_WADAdhpc_prodotti, $schede) or die(mysql_error());
$row_WADAdhpc_prodotti = mysql_fetch_assoc($WADAdhpc_prodotti);
if (isset($_GET['totalRows_WADAdhpc_prodotti'])) {
$totalRows_WADAdhpc_prodotti = $_GET['totalRows_WADAdhpc_prodotti'];
} else {
$all_WADAdhpc_prodotti = mysql_query($query_WADAdhpc_prodotti);
$totalRows_WADAdhpc_prodotti = mysql_num_rows($all_WADAdhpc_prodotti);
$totalPages_WADAdhpc_prodotti = ceil($totalRows_WADAdhpc_prodotti/$maxRows_WADAdhpc_prodotti)-1;
$maxRows_WADADynListdhpc_prodotti = 1000;
$pageNum_WADADynListdhpc_prodotti = 0;
if (isset($_GET['pageNum_WADADynListdhpc_prodotti'])) {
$pageNum_WADADynListdhpc_prodotti = $_GET['pageNum_WADADynListdhpc_prodotti'];
$startRow_WADADynListdhpc_prodotti = $pageNum_WADADynListdhpc_prodotti * $maxRows_WADADynListdhpc_prodotti;
$query_WADADynListdhpc_prodotti = "SELECT DHPC_Descrizione_tipo, DHPC_Descrizione_tipo FROM dhpc_prodotti ORDER BY dhpc_Marca";
$query_limit_WADADynListdhpc_prodotti = sprintf("%s LIMIT %d, %d", $query_WADADynListdhpc_prodotti, $startRow_WADADynListdhpc_prodotti, $maxRows_WADADynListdhpc_prodotti);
$WADADynListdhpc_prodotti = mysql_query($query_limit_WADADynListdhpc_prodotti, $schede) or die(mysql_error());
$row_WADADynListdhpc_prodotti = mysql_fetch_assoc($WADADynListdhpc_prodotti);
if (isset($_GET['totalRows_WADADynListdhpc_prodotti'])) {
$totalRows_WADADynListdhpc_prodotti = $_GET['totalRows_WADADynListdhpc_prodotti'];
} else {
$all_WADADynListdhpc_prodotti = mysql_query($query_WADADynListdhpc_prodotti);
$totalRows_WADADynListdhpc_prodotti = mysql_num_rows($all_WADADynListdhpc_prodotti);
$totalPages_WADADynListdhpc_prodotti = ceil($totalRows_WADADynListdhpc_prodotti/$maxRows_WADADynListdhpc_prodotti)-1;
$queryString_WADAdhpc_prodotti = "";
if (!empty($_SERVER['QUERY_STRING'])) {
$params = explode("&", $_SERVER['QUERY_STRING']);
$newParams = array();
foreach ($params as $param) {
if (stristr($param, "pageNum_WADAdhpc_prodotti") == false &&
stristr($param, "totalRows_WADAdhpc_prodotti") == false) {
array_push($newParams, $param);
if (count($newParams) != 0) {
$queryString_WADAdhpc_prodotti = "&" . htmlentities(implode("&", $newParams));
$queryString_WADAdhpc_prodotti = sprintf("&totalRows_WADAdhpc_prodotti=%d%s", $totalRows_WADAdhpc_prodotti, $queryString_WADAdhpc_prodotti);
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
In your code it looks like you are using the same input for the value of both search criteria:
This will not give you any results because you are saying, 'give me the values from this column where S_dhpc_Prezzo is less then or equal to the value in the db, AND where S_dhpc_Prezzo is greater than or equal to the value'. This does not make sense and will not yield any results for you. Instead you must have two separate form elements, one for the minimum value and another for the max value. Use the max value one with the <= criteria, and the minimum value one for the >= criteria.
I had not seen. I know a little PHP. I have corrected, but there is no improvement, unfortunately...
This is my forms (building with DataAssist)
<form action="lista-prodotti-cercati.php" method="get" name="WADASearchForm" id="WADASearchForm">
<div class="WADAHeader">Search</div>
<div class="WADAHorizLine"><img src="WA_DataAssist/images/_tx_.gif" alt="" height="1" width="1" border="0" /></div>
<table class="WADADataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th class="WADADataTableHeader">DHPC_Descrizione_tipo:</th>
<td class="WADADataTableCell">
<select name="S_DHPC_Descrizione_tipo" id="S_DHPC_Descrizione_tipo">
do {
<option value="<?php echo $row_WADADynListdhpc_prodotti['DHPC_Descrizione_tipo']?>"><?php echo $row_WADADynListdhpc_prodotti['DHPC_Descrizione_tipo']?></option>
} while ($row_WADADynListdhpc_prodotti = mysql_fetch_assoc($WADADynListdhpc_prodotti));
$rows = mysql_num_rows($WADADynListdhpc_prodotti);
if($rows > 0) {
mysql_data_seek($WADADynListdhpc_prodotti, 0);
</select>
</td>
</tr>
<tr>
<th class="WADADataTableHeader">dhpc_Sigla:</th>
<td class="WADADataTableCell"><input type="text" name="S_dhpc_Sigla" id="S_dhpc_Sigla" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">dhpc_Prezzo:</th>
<td class="WADADataTableCell"><input type="text" name="S_dhpc_Prezzo" id="S_dhpc_Prezzo" value="" size="32" /></td>
</tr>
<tr>
<td class="WADADataTableCell"><input type="text" name="S_dhpc_Prezzo2" id="S_dhpc_Prezzo2" value="" size="32" /></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" name="Search" id="Search" value="Search" alt="Search" src="WA_DataAssist/images/Pacifica/Refined_search.gif" /></td>
</tr>
</table>
</div>
</form>
This is the correct statement.
$WADbSearch1->addComparisonFromEdit("dhpc_Prezzo","S_dhpc_Prezzo2","AND",">=",1);
The results is: No results for your search, but i have records for the condition :(
Thanks for the effort on this, I can tell that you are trying a few things to get the desired result. I have opened a ticket for you so that we can exchange some files and do some testing with your data. To update the ticket please login to the site and go to your support history.
