Validate User in the database
Thread begun 10/22/2009 7:50 pm by arteydiseno381654 | Last modified 10/26/2009 12:38 pm by Jason Byrnes | 2590 views | 3 replies |
arteydiseno381654
Hello!
How can I validate a record database with validation toolkit. for example if I want to verify if a user exists in the database.
Thanks !
Create a recordset named duplicateUser on the registration page. Set this to filter the Username column on the Username form element.
Then apply server Validation. use Numeric validation. for the Server variable enter:
$totalRows_duplicateUser
Set the minimum number to -1 and the maximum to 0.
anonymous
Would it not be faster to just the user authentication behavior either with Dreamweaver's built in behavior or Security Assist?
The check new user name behavior will only work with Dreamweavers Insert record server behavior. If you use the DataAssist insert record server behavior instead, you would have to first set it up using the DW Insert, apply the check new user name behavior. A hidden form element is used for triggering the check new user, you need to copy that, then remove the DW Insert , apply the DA Insert then past the hidden form element back for the check new user behavior to function.
after doing this, the check new user behavior will no longer be editable.
It can be done either way, but for compatibility with the DA Insert, it's a bit easier to use the security assist method instead.
