video upload not working
Thread begun 10/22/2009 3:41 pm by chssagmi366905 | Last modified 10/29/2009 11:36 am by Francois | 4071 views | 5 replies |
chssagmi366905
I start with a blank php page and add digital upload but nothing happens. I'm testing locally so I have permissions and the file size is 10 mb. Without changing anything here is what the wizard produces.
No errors show up.
<?php require_once("../WA_DigitalFilePro/HelperPHP.php"); ?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../videos/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["upload"])){
WA_DFP_UploadFiles("WA_UploadResult1", "video", "2", "[NewFileName]_[Increment]", "false", $WA_UploadResult1_Params);
<?php require_once('../Connections/dbc.php'); ?><?php
// start session varible
if (!isset($_SESSION)) {
session_start();
error_reporting(E_ALL);
By default, php will only allow uploads of 2MB. you will need to change some settings in the PHP.ini file to allow for larger files.
before going along this path,. make sure that smaller files can be uploaded. then reconfigure php for larger file.
See the following website for information on PHP settings that affect the size of the files that can be uploaded:
wap_upload.asp?page=php2
chssagmi366905
stil upload problems
my directives are as follows:
upload_max_filesize = 115
post_max_size = 120
memory_limit = 128
max_input_time = 180
max_execution_time = 100
Below is the error message that displays after I attempt to upload and click the "Done" in the status bar.
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.0; Trident/4.0; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.21022; .NET CLR 3.5.30729; .NET CLR 3.0.30618)
Timestamp: Fri, 23 Oct 2009 22:39:49 UTC
Message: 'WADFP_Theme_Options' is undefined
Line: 64
Char: 1
Code: 0
URI: member_videoGallery2.php
this is an error with the progress bar.
please send a copy of your page so I can examine the code.
chssagmi366905
you're correct
I deleted the progress bar and everything worked correct. I will have to get back with you on the progress bar not working.
Francois
had the same, solved
I had the same problem and solved it:
In the head, there is a link to WA_DigitalFilePro/jquery-blockui-formprocessing.js
The link was not valid! I had to add ../ in front and everything worked fine. Hope it helps you.
